const int minUpper = 1.0; //To enter the valid value
const int maxUpper = 80.0;
const int minLower = 1.0; //To enter the valid value
const int maxLower = 50.0;
const int minRefresh = 1.0; //To enter the valid value
const int maxRefresh = 20.0;
int threshold(String command1,String command2,String command3)
int val1 = command1.toInt();
if(minUpper <= val1 && val1<= maxUpper)
upperlimit=val1;
EEPROM.write(2003,upperlimit);
return val1;
int val2 = command2.toInt();
if(minLower <= val2 && val2<= maxLower)
lowerlimit=val2;
EEPROM.write(2004,lowerlimit);
return val2;
int val3 = command3.toInt();
if (minRefresh <= val3 && val3 <= maxRefresh)
refresh = val3;
EEPROM.write(2005,refresh);
return val3; // return the new value and carry on with that
The above code defines Particle.function() .My question is Can we have a code like this where we can pass 3 arguments using one Particle.function(“upper,lower,duration”,threshold);
When I compiled this code I got an error saying that
“invalid conversion from ‘int ()(String, String, String)’ to 'int ()(String)’ [-fpermissive]”
How to overcome this issue?
