Regarding JSON parse
Which one is it?
#include <ArduinoJson.h>
#include <MQTT.h>
const char* myID;
char json[] = "{\"upper\":\"50\",\"lower\":\"20\",\"gap\":\"1\"}";
int upperlimit=5,lowerlimit=2;
int refresh=1;
String macID;
StaticJsonBuffer<200> jsonbuffer;
//-------------------------------MQTT callback function--------------------------------------//
byte server[] = { 174,138,116,138 };//the IP of broker
void callback(char* topic, byte* payload, unsigned int length);
MQTT client(server, 1883, callback);
    char p[length + 1];
    memcpy(p, payload, length);
    p[length] = NULL;
    String message(p);
    Serial.println("Topic subscribed in callback function");
    Serial.print("Before = ");
    Serial.println(p);
    JsonObject& root = jsonbuffer.parseObject(p);
    Serial.print("After = ");
    Serial.println(p);
    delay(5000);
    if (!root.success())
      Serial.println("parseObject() failed");
      return;
     int up = root["upper"];
     int low= root["lower"];
     int space = root["gap"];
     upperlimit = up;
     EEPROM.write(2003,upperlimit);
     lowerlimit = low;
     EEPROM.write(2004,lowerlimit);
     refresh = space;
     EEPROM.write(2005,refresh);
     Serial.println(upperlimit);
     Serial.println(lowerlimit);
     Serial.println(refresh);
     delay(1000);
     System.reset();
if (client.isConnected())
  client.subscribe(myID);
  upperlimit=(int8_t) EEPROM.read(2003);
  lowerlimit=(int8_t) EEPROM.read(2004);
  refresh=(int8_t) EEPROM.read(2005);
 macID=System.deviceID();
 myID=macID.c_str();
 client.connect(System.deviceID());
      client.loop();
      Serial.println("Connected");
     delay(2000);
this code Sir.The code is working fine as expected but the drawback is when I change my values from CLI the device forcibly needs to be reset inorder to reflect the changes in my code.So I used System.reset() function.
I found this by removing System.reset() and tested but the parsing used to failed for the second time when I tried to change my values from CLI ,so the alternate I found was to reset the device.Hence the above code was final.
So any suggestions on this.
If device is to be reset the memory values are lost in EEPROM.So I want to eliminate that resetting but if removed I cannot parse the fresh values from CLI.
this part
I solved this part Sir.
I used ‘(int8_t)’ which worked for me to retrieve negative values from EEPROM.
refresh= EEPROM.read(2005);
The whole idea of EEPROM is that the values are retained even when power is lost. So, if that isn't the case, then there's most likely something wrong with the way you're using EEPROM.
if, during the callback, you write to your global variables, they should be available in the entire program. Have you tried breaking this thing up in pieces yet? Rather than doing everything at once, make sure the separate pieces work as intended trying to do it all?
Nope I tried by breaking the code and after analyzing only I changed the code.
Yes values are retained in EEPROM,they are not affected.But I have a fear of losing stored data when I reset my device using software function.
So I am asking the suggestion.
Now my code is working fine as expected but I am trying to remove the ‘System.reset()’ part in my callback function.
If I remove that ‘System.reset()’ I can parse for the first time not for second or third…so on which means a trouble when user enters his own values from CLI those values are parsed only once and not beyond that.
So I sticked to use ‘System.reset()’ function in my code.So that when new changes are made in values from CLI.
If ‘System.reset()’ is removed I can confidently say that code is still better.
Hello Sir,
Happy to inform you that I found the solution for avoiding reset.
#include <MQTT.h>
const char* myID;
//char json[] = "{\"upper\":\"50\",\"lower\":\"20\",\"gap\":\"1\"}";
int refresh=1;
String macID;
    StaticJsonBuffer<200> jsonBuffer;
   // JsonObject& root = jsonbuffer.parseObject(json);
    char p[length + 1];
    p[length] = NULL;
   // String message(p);
    Serial.println(p);
    JsonObject& root = jsonBuffer.parseObject(p);
    Serial.println(p);
   // delay(5000);
      return;
     upperlimit = up;
     lowerlimit = low;
     refresh = space;
     delay(1000);
     //System.reset();
 myID=macID.c_str();
      client.loop();
     delay(2000);
The issue was just adding the line —> StaticJsonBuffer<200> jsonBuffer; inside my callback function.
After adding inside the callback function I solved my problem of resetting the device.
Now as I said “A BETTER CODE” on my device.
Thank you for supporting me Sir.
Thanks a lot
You had been given a solution to that System.reset() problem of yours already over a month ago - you just didn’t seem to care to think through provided suggestions.
BTW, you were also told how to format code in forum posts, we keep reformatting it to keep the threads tidy - spare us the extra work by doing it right, please.
Forum Etiquette
Forum Tips and Tricks
We don’t mean to discourage people from asking questions, but we also need to protect our own sanity.
Please don’t become a so called Help Vampire
Sir this was not the old problem.
The old problem is already solved.Now the problem was for MQTT callback function.
I have updated the code as per your suggestions and have not neglected them.I have used 100% of your suggestions which has built confidence to code.
I thank you for that.
And now even this new reset issue was solved by myself where I learnt the debugging skills and analyse the problem well with your valued suggestions on forum.
I would like to have a guide like you.
If any mistakes I have made or hurted you please forgive me.
Hmm, how about that then
This I have applied already.Its working
I know, but that hint was provided over a month before you rose the question here again.
