I am trying to get 3 values from JSON string from the server and I have my code is here :
#include <ArduinoJson.h>
#include <MQTT.h>
char json[] = "{\"x\":\"upper\",\"y\":\"lower\",\"z\":\"gap\"}";
int refresh=1
float tempC,upperlimit=5.0,lowerlimit=2.0;
StaticJsonBuffer<200> jsonbuffer;
byte server[] = { 174,138,116,138 };//the IP of broker
void callback(char* topic, byte* payload, unsigned int length);
MQTT client(server, 1883, callback);
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
String message(p);
JsonObject& root = jsonbuffer.parseObject(json);
if (!root.success())
Serial.println("parseObject() failed");
return;
int x = root["x"];
int y = root["y"];
int z = root["z"];
upperlimit = x;
EEPROM.write(2003,upperlimit);
lowerlimit = y;
EEPROM.write(2004,lowerlimit);
refresh = z;
EEPROM.write(2005,refresh);
Serial.println(x);
Serial.println(y);
Serial.println(z);
delay(2000);
This is my MQTT callback function, where I am parsing the JSON string and copying to 3 different variables.
So the issue is when I send values from CLI in Ubuntu as -->
What have you tried so far?
Try printing the raw JSON before parsing to make sure if it arrives in a sensible format.
Try to make it parse correctly with hard-coded JSON.
Then combine the two?
w.r.t above code I added these 2 lines to check whats being stored and I got the result on Serial monitor as
{âxâ:â33â,âyâ:â24â,âzâ:â5â} // this is for , Serial.println§;
x // this is for , Serial.println(json);
I know that, but seeing as the parsing part is working, itâs a matter of making sure the MQTT message arrives in the same format as the example. If so, then thereâs no reason why that shouldnât work either.
Try comparing the data you receive from the MQTT subscription with that in the example, and try to figure out what you have to change?
Try reading the docs again on EEPROM and make sure the addresses and sizes involved are correct. Take care not to overlap them.
Currently, you're not doing anything with the data you send over MQTT, you're still parsing the hard-coded string. As such, you can try my minimalist sketch first to ignore any complications due to MQTT.
Try approaching the project in steps. Make sure JSON parsing works correctly. Then, try sending a string over and make sure it arrives the way it's supposed to. Then combine those.
I see in your code you are still not applying the hints you got a long time ago when I commented about EEPROM.write() not being the way to store float variables.
I wonder why we answer questions when our answers aren't really taken into consideration.
#include <MQTT.h>
const char* myID;
char json[] = "{\"upper\":\"30\"}"; //,\"lower\":\"20\",\"gap\":\"1\"}";
int upperlimit=5,lowerlimit=2;
int refresh=1;
String macID;
//-------------------------------MQTT callback function--------------------------------------//
char p[length + 1];
p[length] = NULL;
String message(p);
Serial.println("Topic subscribed in callback function");
Serial.print("Before = ");
Serial.println(p);
//JsonObject& root = jsonbuffer.parseObject(json);
Serial.print("After = ");
Serial.println(p);
JsonObject& root = jsonbuffer.parseObject(p);
delay(5000);
return;
int up = root["upper"];
int low= root["lower"];
int space = root["gap"];
upperlimit = up;
lowerlimit = low;
refresh = space;
Serial.println(up);
Serial.println(low);
Serial.println(space);
//delay(1000);
if (client.isConnected())
client.subscribe(myID);
upperlimit=EEPROM.read(2003);
lowerlimit=EEPROM.read(2004);
refresh=EEPROM.read(2005);
macID=System.deviceID();
myID=macID.c_str();
client.connect(System.deviceID());
client.loop();
Serial.println("Topic subscribed");
Serial.println(upperlimit);
Serial.println(lowerlimit);
Serial.println(refresh);
delay(1000);
Right now I was working with this updated code Sir.
I have tried your suggestions and satisfied with that and it has helped me during my other project.I am thankful to you Sir.
But right now I am facing this issue when I use CLI of ubuntu and send my JSON string using MQTT publish command where I am subscribing that topic in my code.
The message is being copied as it is in String âpâ but error in parsing that string.Since I dont even know the abc of JSON the reason why I am so troubled.
Sorry _
figuring out what JSON is (Google is your friend here)
Transmitting JSON data over MQTT, and making sure itâs formatted correctly on the receiving end. Donât check this by subscribing on your computer, but have the Photon print it so you can compare it to something you know is working.
Parsing JSON. Youâve got a working example. As long as the data youâre receiving matches that, thereâs no reason why that wouldnât work.
Saving that parsed JSON to variables. Make sure the data types are chosen correctly.
Saving data to EEPROM. Again, mind you datatypes and addresses. Give the docs a good read or two.
Donât try to do everything at once, but break it up into manageable steps.
Also, donât keep on repeating the same question over and over again, hoping one of us will spoon-feed you the answer. Youâre going to have to put in some effort on your own. Youâve repeatedly mentioned you donât know anything about JSON; why not go read up on that first then?
#include <MQTT.h>
const char* myID;
char json[] = "{\"upper\":\"50\",\"lower\":\"20\",\"gap\":\"1\"}";
int refresh=1;
String macID;
char p[length + 1];
p[length] = NULL;
// String message(p);
Serial.println(p);
Serial.println(p);
delay(5000);
return;
upperlimit = up;
lowerlimit = low;
refresh = space;
delay(1000);
System.reset();
upperlimit=(int8_t) EEPROM.read(2003);
lowerlimit=(int8_t) EEPROM.read(2004);
refresh=(int8_t) EEPROM.read(2005);
myID=macID.c_str();
client.loop();
Serial.println("Connected");
delay(2000);
I found the solution for my problem,
the issue was --> JsonObject& root = jsonbuffer.parseObject§; I replaced the parsing object as âpâ instead of json.
Also while reading the negative values I used (int8_t) typecasting to get the negative numbers stored in EEPROM.
But one bad thing is I want to use System.reset() function whenever I update new values from CLI.So is there any ways that I can remove that System.reset() part so my code runs without resetting the device.
