I'm using two legged authentication which work find until I get token expired.
I stored the refresh_token when I got the response:
"token_type": "bearer",
"access_token": "<--redacted-->",
"expires_in": 7776000,
"refresh_token": "<--redacted-->"
Then if the token invalid then I use refresh_token to get the new one.
curl https://api.particle.io/oauth/token -u "tempmon06-3459:<--redacted-->" -d grant_type= refresh_token
All works well, but until I have an account which doesn't login a long time(more than 90 days I think) then I got token invalid error again. I think refresh_token has expired. not sure if correct.
Then I changed my strategy to create new token every time the token expires by using
curl https://api.particle.io/oauth/token -u "tempmon06-3459:<--redacted-->" -d grant_type= client_credentials
Which works fine. Then I inject successfully the token and try to use it. I got the new token. But when setup WIFI, it fails on the last step "X Verify device ownership"
Like this image I found in the community.
Not sure what should I do next. Does the way I create new token is wrong, or did I missed any important step?
What I am thing is when generate the new token the token doesn't know which user? If so I used this way:
which is
curl -X POST https://api.spark.io/oauth/token \
-d 'username=<YOUR_PASSWORD> \
-d 'password=<YOUR_PASSWORD>' \
-d 'grant_type=password' \
-d 'client_id=<WHATEVER>' \
-d 'client_secret=<WHATEVER>'
But still no luck.
Any help? thanks a lot!
