Red flashing electron
I am not able to load a program OTA using the thingspeak library. While doing this I get a series of red, blue and white flashes. here is no discernible pattern. Here is a copy of the code.
I would like to upload a short video but not available
Have any suggestions?
#include <ThingSpeak.h>
unsigned long  myChannelNumber= !!9247;
const char * myWriteAPIKey = "!!QE6YDDSA2EIML4";
#include "Adafruit_DHT.h"
// Example teting sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#define DHTPIN 2     // what pin we're connected to
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11		// DHT 11
#define DHTTYPE DHT22		// DHT 22 (AM2302)
//#define DHTTYPE DHT21		// DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
	Serial.println("DHTxx test!");
	dht.begin();
// Wait a few seconds between measurements.
	delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a
// very slow sensor)
	float h = dht.getHumidity();
// Read temperature as Celsius
	float t = dht.getTempCelcius();
// Read temperature as Farenheit
	float f = dht.getTempFarenheit();
// Check if any reads failed and exit early (to try again).
	if (isnan(h) || isnan(t) || isnan(f)) {
		Serial.println("Failed to read from DHT sensor!");
		return;
// Compute heat index
// Must send in temp in Fahrenheit!
	float hi = dht.getHeatIndex();
	float dp = dht.getDewPoint();
	float k = dht.getTempKelvin();
	Serial.print("Humid: ");
	Serial.print(h);
	Serial.print("% - ");
	Serial.print("Temp: ");
	Serial.print(t);
	Serial.print("*C ");
	Serial.print(f);
	Serial.print("*F ");
	Serial.print(k);
	Serial.print("*K - ");
	Serial.print("DewP: ");
	Serial.print(dp);
	Serial.print("*C - ");
	Serial.print("HeatI: ");
	Serial.print(hi);
	Serial.println("*C");
	Serial.println(Time.timeStr());
	///  ThingSpeak.writeField(myChannelNumber, 1, voltage, myWriteAPIKey);
  ThingSpeak.writeField(349247, 1, f, "!!!!UB2QE6YDDSA2EIML4");
//thingspeak.writefield(myChannelNumber,1,f,myWriteAPIKey);
//thingspeak.writefield(myChannelNumber,2,h,myWriteAPIKey);
delay (30000);
You can upload a video to any video platform (e.g. YouTube or vimeo) and post the link.
Thanks - will do
Here is a video of the blinking problem. Any idea on how to fix?
This is a distinct pattern.
It’s the normal startup till breathing cyan and then after a few moments the SOS panic pattern follws, but then when it starts to get interesting the video stops.
The blink count after the SOS would be the important info.
A video is below
Thanks for the great response. I count
3 short red
3 long red
3 short red
1 red
9 red
1 red
then
white
green
flash light blue
Here is the video
I made progress. I flashed Tinker back on my electron and then removed extra code from DHT example. The Electron is now in a light blue mode. I can flash a simple code like this and it is working int led = D7;
pinMode(led, OUTPUT);
digitalWrite(led, HIGH);
delay(4000);
digitalWrite(led, LOW);
delay(500);
When I run the Thingspeak code I get the same error.
Reading further I see that 9 flashes is SPI overrun.
When I strip out the thingspeak libraries, it gets uploaded.
I bet it is something in the thingspeak library
These 9 flashes are a second SOS pattern. The single blink between the two SOSs iscwhat counts (hard fault).
Probably caused by the ThingSpeak library.
What system version are you targeting?
And what ThingSpeak version?
I am using version 6.2 and thingspeak1.3.0
I know this is an old thread, but in case anyone else comes here because they have this problem, there is a line of code missing in Setup() that causes this failure.
ThingSpeak.begin(client);  // Connect to ThingSpeak
In the ThingSpeak examples they also have this which I do not see in this program either:
TCPClient client;  /* Thingspeak */
