Hello,
Not sure if this is the right thread for this but I hope it’s fine…
I’m not very familiar with programming and I’m getting red flashes on my photon after calling the following function. I followed the example code from the included libraries and tried to troubleshoot it myself but I don’t see what I’m missing.
// This #include statements add functionality for the humidity Sensor
#include <DHT.h>
#include <Adafruit_Sensor.h>
#define DHTTYPE DHT11
#define DHTPIN D2
int Humidity,Temperature;
DHT dht(DHTPIN, DHTTYPE);
SYSTEM_MODE(SEMI_AUTOMATIC);
/* This function is called once at start up ----------------------------------*/
WiFi.on();
Particle.function("CheckSensor", Dht);
//Register the functions for the sensor
dht.begin();
// It's important to do this here, inside the setup() function rather than outside it or in the loop function.
int Dht(String command)
{if (command=="on") {
//Read Humidity
int h = dht.readHumidity();
// Read temperature as Celsius
int t = dht.readTemperature();
Humidity=(int)h;
Temperature=(int)t;
delay(2000);
//Take temperature and humidity readings and publish the results
Particle.publish("Temperature", String(Temperature) + "°C");
delay(2000);
// Wait a few seconds between measurements.
Particle.publish("Humidity", String(Humidity) + "%");
delay(2000);
