Recommendations for Tachyon 5G board Camera stream over its 5G cellular connectivity
I would like to know the possibilities of using 5G network capability of the Tachyon 5G board to stream camera from this board to the cloud services from my UK. Are there any recommended 5G service provider for this board for this kind of streaming please?
Hey @ramkoppu I put together a sample repository that uses AWS Kinesis Video Streams for video retention and playback. It might be a worthwhile place to start! I’ll have a full step-by-step write up soon.
The Tachyon will connect to the best available provider available to it in the UK, you should not need to source your own SIM profile.
Is the e-SIM comes with the board provides enough bandwidth to stream video from Adrucam 16MP IMX519 camera module?
Yes, the bandwidth should not be a problem, but you will have to calculate your data usage expectations.
Thanks @ericpietrowicz, just ordered the board, once I receive it I will try this repo for camera streaming
Hi @ericpietrowicz Looking to trying this out and your step-by-step guide. Thanks.
Check the Thread “Camera not working”. Currently, even though listed as 100% compatible, it is not. Latest updates to Ubuntu 20 still will not let you focus on anything. Just FYI, maybe it is fixed by the time you get your board.
