Recommend a long-lasting battery
The only reason I have suggested using tadiran/saft is because; I know British manufactured battery powered RTU’s use these with a HLC combo. And they advertise 5+ years…
I have no experience or knowledge of any other
Edit/ They use Sierra Wireless modems instead of UBlox but I should imagine they have similar power consumption, without knowing the exact part number and seeing the data sheet etc
In a related topic (Powering Electron with LiPo and VIN with Batteries - #3 by ScruffR) @ScruffR mentioned:
So assuming the voltages would be very similar (3.7V for LiPo, 3.6V for Tadiran) this would mean draining in parallel?
If that is the case, then you could look at having a HLC in parallel with a Tadiran connected to VIN and don’t use the LiPO. The HLC should be able to cope with the current Spike from the modem and then get topped up again by the Tadiran… I’m sure there is more to it, than just that though.
Oh interesting! The page where you took that from had it listed at $40, which seems like a very considerable amount, and a bit tricky to make?
I wonder if anyone has any other (maybe cheaper?) alternatives. If there’s any other to just recharge the LiPo using a 2nd battery that’d be great.
Just had a quick read of the data sheet… could you keep the LiPo connected and connect the Tadiran to the USB instead of VIN?
It says, it will intelligently take power from the USB most of the time and keep the battery charged
This one here: https://www.alibaba.com/product-detail/D-size-3-6V-14Ah-SAFT_60348111098.html actually claims to support up to 3500mA pulses, so it should be sufficient for the Electron it seems.
Out of curiosity I can also see if I can somehow hook up my battery to the USB port
I’m not sure I would trust a Chinese alternative battery, after so many reports of them in the news catching fire/exploding etc especially if you are using them in an enclosed area… they are cheaper for a reason.
This is worth a read to understand the difference between bobbin and spiral wound batteries…
http://www.tadiranbat.com/compare-lithium-cells.html
Thinking about this more, I would buy a SAFT LSH 20 and connect it to the Li+ PIN
LI+
This pin is internally tied to the positive terminal of the LiPo battery connector. It is intentionally left unpopulated. Please note that an incorrect usage of this pin can render the Electron unusable.
Li+ pin serves two purposes. You can use this pin to connect a LiPo battery directly without having to use a JST connector or it can be used to connect an external DC power source (and this is where one needs to take extra precautions). When powering it from an external regulated DC source, the recommended input voltage range on this pin is between 3.6V to 4.4VDC. Make sure that the supply can handle currents of at least 2 Amps.
This is the most efficient way of powering the Electron since the PMIC by-passes the regulator and supplies power to the Electron via an internal FET leading to lower quiescent current.
The reason behind this is because, using VIN the Voltage range is 3.9 - 12VDC and using the LiPO Connector the voltage is 3.7VDC... where the SAFT is 3.6VDC.
Thanks for the help, yeah. It does seem like LiSOCl2 batteries with a support for higher peak currents (such as the LSH 20) are my best bet. They do generally seem quite a bit more expensive, but at least the solution is straightforward with a single battery juicing up the Electron through two wires.
I had a chat with someone from Tadiran a ways back and he gave me this PDF which explains how a primary (non-rechargeable) + secondary (rechargeable) option is the way to go when it comes to wireless sensors.
http://www.tadiranbat.com/assets/tadiran-batteries-3-14_reprint-design-world_online.pdf
He provided me with this PDF sheet that sort of explains how they work. I asked him if he had a schematic that could help my application to switch between the primary/secondary batteries when the current demand from the load (the Electron UBLOX in this case) increases, but the conversation ended there. Pretty sure it’s because he didn’t see value in following through because of my low-volume.
Would be great if someone else had some thoughts on this as well. I have a low-peak LiSOCl2 battery ready to be used, just not sure how I should set it up and how to monitor it to check if indeed the LiPo is being recharged by the LiSOCl2…
You could run two LiSOCl2 in series and connect to the USB port.
This way you’ll have enough voltage to run through USB and the Electron will intelligently use the LiPo for the extra current draw from the modem.
Does seem like a waste of an LiSOCl2 just for an extra volt, you could try it with just one I suppose.
You got me curious again @Vitesze. I did some additional research on a chip solution to this primary/secondary, and maybe…just maybe…you could utilize the LTC4415 from Linear.
My thought is, you could use the EN1 and EN2 (enable) pins on the IC, controlled by digital outputs on the Electron, to switch to the Primary (non-rechargeable) battery when the Ublox module is transmitting, and then switch to the Secondary (rechargeable) battery for the rest of the time when the Electron is finishing up code and sleeping / deep-sleeping.
It’s not a perfect solution because it’s not actually detecting the current from the load and switching to the primary battery, but maybe it can be used in conjunction with that.
The output of the LTC4415 would go to Li+.
Unknown: I haven’t read the whole datasheet but don’t know if the switching between batteries has a delay that would shutdown the Electron because it’s not receiving power.
Interesting. I already have a 3.6V 14Ah LiSOCl2 battery on the way, that supports 1.8Ah peaks. If it doesn’t work as I hope (or if I just feel adventurous :smiley_cat:) I will try what you and Alph suggested and see how far I get. The thing is though, would the LiSOCl2 be recharging the LiPo? As in my code whenever my sensor isn’t in deep sleep, it spends more than half of its time retrieving geodata (making call to cell tower), so I imagine that would drain the LiPo quite a bit as well.
You mean, the battery can support a peak current of 1.8A?
Yes, running code continuously means that the microprocessor is always on, which also drains the battery. Unless you are in a deep sleep mode (both cellular and microprocessor modules off), your battery will not last 2-3 years, even if it’s 14Ah.
What you should probably do is use semi-automatic mode:
Turn off cellular modem.
Take a measurement, then go to normal sleep.
Wake up, take a another measurement, go back to sleep.
At the end of the day, turn on the cellular modem, output the data to the cloud, rinse, repeat.
My Electron actually will be in deep sleep mode for 99.9% of the day, only taking measurements for 1-2 minutes per day, before going back to sleep. That’s why I ultimately went with LiSOCl2-batteries. They have super low self-discharge rates of only 1% per year.
The new battery arrived by mail yesterday actually and it works like a charm - enough voltage and can handle the peak currents well.
Ah okay, guess I mis-read that then.
To answer your question on if the LiSOCl2 will be recharging the LiPo. It depends on how which pins are connected and how you have it wired. It’s definitely possible.
What would the point of it though? I can see the use of it with an extra battery that cannot handle the peaks (and therefore you rely on the LiPo to do it) but in this case the LiSOCl2 battery can handle the peaks by itself already. The added capacity (2Ah for default Particle LiPo) is only marginal.
All this planning about using low self-discharge LiSOCl2 batteries at VIN, and no one even once mentioned that the deep sleep current is 2-3 mA when a battery is connected at VIN!!
Please see this thread: Electron Deep Sleep current when powering from VIN without LiPo for the same.
We also had been thinking of using batteries at VIN and had designed a custom PCB for this, only to realize later that VIN had such a high quiescent current. That claimed 130 uA sleep current is only for the Li+ pin.
Particle should really make this thing more clear in their documentation.
For my money, I’ll always go with the Energizer® Ultimate Lithium™ AA batteries. I’ve had 4 of them outside working a mailbox notification system. They have been working outdoors for over 2 years and haven’t dropped below 6.6v.
