Hi All,
I’m new to Spark and I may be making a total beginners error, but I’m seeing events from board IDs that I don’t control. My board id ends with 0687, but you can see below that I’m getting events from other people’s boards. Any idea what is happening? Does this have to do with public vs. private events? How do I get events from only my board? Also, how do I hide my events from other people? Thanks in advance!!
In the IDE, I have:
Spark.publish("temperature", "19 F");
In the terminal I typed:
curl -H "Authorization: Bearer <my_access_token>" https://api.spark.io/v1/events/temperature
Curl is returning:
event: temperatureInfo
data: {"data":"59.67","ttl":"60","published_at":"2015-03-07T23:07:12.805Z","coreid":"54ff6e066678574930210267"}
event: temperature
data: {"data":"1838","ttl":"60","published_at":"2015-03-07T23:07:12.835Z","coreid":"55ff72066678505526261367"}
event: temperature
data: {"data":"342810","ttl":"60","published_at":"2015-03-07T23:07:13.196Z","coreid":"55ff71066678505518151367"}
event: temperature
data: {"data":"{loc: 8,temp: 22.94}","ttl":"60","published_at":"2015-03-07T23:07:14.822Z","coreid":"51ff6a065067545741340187"}
