Hello Guys,
I’m working on a project: I’m trying to send data from a Renesas microcontroller to the Photon (Throught UART) and then send these data from the photon to a server (using UDP packet).
The first part of the project is working good (i can send a character throught UART)
And the second Part is also working good (I tryed to send a character from the photon and i can see it coming to the server using Putty) but it is not the same character that i sent.
Now i want to connect between the 2 parts of the project and try to send the same character to the server that i already received throught UART but i have always errors on my code…
Here is my code:
UDP Udp;
char Buffer1; // This Buffer is used to save data coming from the Renesas controller
IPAddress remoteIP(10, 0, 40, 30); // IP Adress of the server (Trac server)
int port = 48081; // Open port
char buffer[];
Serial1.begin(57600); // intialisation of the the UART
while(Serial1.available()) {
Buffer1=Serial1.read(); // Read whats in the Serial port and store to Buffer1
//Serial1.write("The Character you sent is ");
//Serial1.write(Buffer1);
buffer = Buffer1; // put the received character into buffer to send it to server
Udp.begin(48081);
Udp.sendPacket(buffer,1,remoteIP,port);
Udp.stop();
Thanks for Answering…
