Read json from webhook
Hi guys. First of all I want to apologize for my English, I am a native speaker of Spanish.
Days ago I’m trying to read the data I get from a webhook that connects to a Firebase database. I just want to read two data sent in a Firebase json (temMax and tempMin).
This is my code to test that function (provided by the webhook that I created):
  Particle.subscribe("hook-response/seteoTemperatura", myHandler, MY_DEVICES);
  String data = String(10);
  Particle.publish("seteoTemperatura", data, PRIVATE);
  delay(6000);
void myHandler(const char *event, const char *data) {
  // In this function I do not know what to do.
The data contained in the json file are just these:
{"tempMax":15,"tempMin":10}
In the console I see this:
If you observe, Particle.publish (“set Temperature”, data, PRIVATE); print the value 10 on the console. If only I could read the other value (15) my problem would be serious, but I do not know what to do anymore.
I tried to follow the tutorial de de @rickkas7 but I was not lucky either … obviously the problem is me hahaha:
https://github.com/rickkas7/firebase_tutorial
I’m sorry for my bad English and for the duration of the publication!!.
I appreciate any help!! Thank you very much.
Regards!! :grin:
There are many ways to do this. One way is to use a JSON parser library; I like JsonParserGeneratorRK.
Add a global variable:
JsonParserStatic<512, 50> jsonParser;
Add this in myHandler:
jsonParser.addString(data);
if (jsonParser.parse()) {
    int tempMax;
    jsonParser.getOuterValueByKey("tempMax", tempMax);
    int tempMin;
    jsonParser.getOuterValueByKey("tempMin", tempMin);
    // Put code to do something with tempMin and tempMax here
Thank you very much @rickkas7, I appreciate very much you have taken the trouble to answer me.
After your answer, my code remained this way
#include <JsonParserGeneratorRK.h>
  Particle.publish("setTemperature", data, PRIVATE);
  delay(6000);
  Particle.subscribe("hook-response/setTemperature", myHandler, MY_DEVICES);
        String tempMax;
        String tempMin;
        Particle.publish("max", tempMax, PRIVATE);
        Particle.publish("min", tempMin, PRIVATE);
In the console I see that the values are published null:
Will my error be found in the webhook configuration?
The weird thing is that the data is shown:
I feel like I’m asking stupid questions and I’m very embarrassed, but I reached the limit that I had no choice but to go and bother them with questions :flushed:
This should be
int tempMax;
The temperature is an integer, not a String. Same for tempMin.
JSON won't automatically convert between String and int. To publish it, use:
Particle.publish("max", String(tempMax), PRIVATE);
I do not know what I thought when I did that. What I could not solve in days you did it in 5 minutes haha.
Thank you very much!! Now I can continue.
I am doing a project for a beer fermentation chamber, when I finish it I would like to share it with you.
Thank you for having so much patience @rickkas7
Regards!
