Random compiler errors on SYSTEM_THREAD(ENABLED);
Hey all!
Thanks for reporting this, I’ve identified the issue, a recent API update changed a behavior when picking the “latest” firmware target for your device. If you explicitly select the version “0.4.7” it should work properly. The update went out earlier this week (Mon/Tues), Sorry we didn’t catch this sooner!
edit: I’ve applied a small patch that should address this for the Photon, but not yet for the P1/ Core. We should have a better fix in place later this week.
Thanks,
David
