Pushing data from the photon into google sheets
I think you could also use IFTTT, because it is much easier.
Your webhook would just have to look like:
    "eventName": "to_google_sheets",
    "url": "https://maker.ifttt.com/trigger/to_google_sheets/with/key/PUT_YOUR_IFTTT_KEY_HERE",
    "requestType": "POST",
    "json": {
        "value1": "{{SPARK_EVENT_VALUE}}"
    "mydevices": true
Replace PUT_YOUR_IFTTT_KEY_HERE with your key from the IFTTT Maker Channel.
To log data, you would just make your Photon do:
Particle.publish("to_google_sheets", "Data_you_want_to_Publish");
