I’m upgrading my Alexa Smarthome skill from using particle-api-js 6.4.3. I’m getting an exception calling particle.publishEvent when I upgrade to 8.0.1 or newer.
Running this code with particle-api-js 8.0.0 works without errors or exceptions.
function publish(name, data, token) {
helper.log("publish name",name);
helper.log("publish data",data);
helper.log("publish token",token);
let args = { name: name, data: data, auth: token }; // New version?
helper.log("publish args",args);
try { // This shouldn't be necessary
return particle.publishEvent(args).then(function(response){
helper.log("publish response",response);
let result = response.body.ok;
return result;
}, function (err) {
helper.log("publish error",err);
} catch(error) {
helper.log("publishEvent exception", error);
On 8.0.1 or newer, I see the “publishEvent exception {}” log.
Also, in the CloudWatch logs I see this shortly after the above message:
2021-02-09T14:08:17.336Z 633e64b8-aeca-4450-83c9-449b22e84524 ERROR Invoke Error
"errorType": "Error",
"errorMessage": "Main - Unknown error",
"stack": [
"Error: Main - Unknown error",
" at _homogeneousError (/var/runtime/CallbackContext.js:12:12)",
" at postError (/var/runtime/CallbackContext.js:29:54)",
" at done (/var/runtime/CallbackContext.js:56:7)",
" at fail (/var/runtime/CallbackContext.js:68:7)",
" at Object.fail (/var/runtime/CallbackContext.js:104:16)",
" at Object.handler (/var/task/src/main.js:74:17)",
" at Runtime.handler (/var/task/index.js:15:10)",
" at Runtime.handleOnce (/var/runtime/Runtime.js:66:25)"
I’m not sure what to do now, besides just staying at v8.0.0. Any suggestions how to proceed or debug further?
