I’m a noob. Love the Particle devices. Experimenting with the Cloud functions: Particle.publish(); & Particle.subscribe() on the Photon.
Just trying to create simple communication twixt 2 Photons where a button pressed on one changes the LED light behavior on another. Writing the code for the “button” photon now. Code with the Particle.publish() expression won’t compile. Here is the error message.
error: no matching function for call to 'CloudClass::publish(const char [13], bool, Spark_Event_TypeDef)'
Here is my code:
#include "Particle.h"
int pushB = D6; // var for button definition
int led = D7; //
pinMode(pushB, INPUT);
pinMode(led, OUTPUT);
if (digitalRead(pushB)){
digitalWrite(led, HIGH); // Turn ON the LED pins
Serial.println(digitalRead(pushB)); // print values to the serial monitor
Particle.publish("change-light", TRUE, PRIVATE);
} else {
digitalWrite(led, LOW); // Turn OFF the LED pins
Particle.publish("change-light", FALSE, PRIVATE);
I don't think you can use 'TRUE' and 'FALSE' like that. Take a look at the example:
// EXAMPLE USAGE
Particle.publish("lake-depth/1", "28m", 21600);
Additionally, mind this:
NOTE: Currently, a device can publish at rate of about 1 event/sec, with bursts of up to 4 allowed in 1 second. Back to back burst of 4 messages will take 4 seconds to recover.
Without rate limiting in your loop, you'll blow over that instantly. You're also going to need some debouncing.
OK, working. Thanks for the pointer. I did this (below). It sends the other photon a message every 1 second with the button state, which is used to change LED behavior via the subscribe event handler:
int led = D7; //
int bState = 0;
int sec_interval = 2;
int prev_second = 0;
button();
secondTimer();
void button() {
bState = 1;
} else {
bState = 0;
void secondTimer(){
int curr_second = (millis() / 1000);
if ((curr_second % sec_interval == 0) && (curr_second != prev_second)) {
if (bState == 0){
Particle.publish("change-light", "0");
Serial.println(bState); // print values to the serial monitor
}else{
Particle.publish("change-light", "1");
prev_second = curr_second;
