Published BetterPhotonButton Library (updated to 0.1.6 / v2)
GitHub
Build.Particle
https://build.particle.io/libs/BetterPhotonButton/0.1.6/
Non-blocking replacement to InternetButton. With this you can easily write animations for the LEDs (17 included), and run them simultaneously with playing notes, reading the accelerometer, and listening for (debounced) button presses.
(This has not changed much in a year but I’ve updated it to the v2 library format and added quite a bit of info to the README on GitHub).
Curious how to become a “verified library” ??
Perhaps you could issue a PR for the original Internet Button library?
I don’t have a Core or SparkButton to check for backwards compatibility.
