Just published the Adafruit_ILI9341 LCD controller library. This library is helpful if you are using a LCD display that uses the ILI9341 controller IC. It requires Adafruit_mfGFX or Adafruit_GFX library as well.
I am trying to run the sample app âas-isâ and keep getting errors (31 total) in the form of:
âstruct GPIO_TypeDefâ has no member named âBRRâ
