I have a particle template installed on Visual Studio 2015. I can create projects ok but having trouble with the library files.
Does the file structure need to be same as DEV -> project/src for source file and project/lib/libname/src for the library source files?
Anyone else using Particle in VS that I can swap notes or pick your brains?
