For some reason, LED1 is blinking randomly.
Code below
int led0Toggle(String command);
int led1Toggle(String command);
int led2Toggle(String command);
int led3Toggle(String command);
int led0 = D0;
int led1 = D1;
int led2 = D2;
int led3 = D3;
pinMode(led0,OUTPUT);
pinMode(led1,OUTPUT);
pinMode(led2,OUTPUT);
pinMode(led3,OUTPUT);
Particle.function("LED0", led0Toggle);
Particle.function("LED1", led1Toggle);
Particle.function("LED2", led2Toggle);
Particle.function("LED3", led3Toggle);
digitalWrite(led0, LOW);
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
int led0Toggle(String command) {
if (command=="ON") {
digitalWrite(led0,HIGH);
return 1;
else if (command=="OFF") {
digitalWrite(led0,LOW);
return 0;
else {
return -1;
int led1Toggle(String command) {
digitalWrite(led1,HIGH);
return 1;
digitalWrite(led1,LOW);
return 0;
else {
return -1;
int led2Toggle(String command) {
digitalWrite(led2,HIGH);
return 1;
digitalWrite(led2,LOW);
return 0;
else {
return -1;
int led3Toggle(String command) {
digitalWrite(led3,HIGH);
return 1;
digitalWrite(led3,LOW);
return 0;
else {
return -1;
