Just got my photon today.
Used the iOS app to set it up, but it keep getting some error message.
The Photon is still blinking blue.
I repeated the process for at least 20 times, using different router, different WIFI security settings (WPA, WPA2, WEP), all with the same results.
Using the CLI, it’s also unable to get connected to the wifi. At the same time, using particle serial identify , it’s able to list the ID, but it’s unable to determine the system firmware version.
Where did I go wrong ?
Spending too much time just to get started.
