Powering Muons with solar
Now we know that to properly power a Muon, and charge its battery, we must use a USB C cable according to this:
I have the following question:
Can I power the Muon by directly connecting a 6V solar panel to its USB C port?
I guess the answer will be that I cannot since 6v is not enough.
So the Muons need 9v or 12v solar panels.
Is this correct?
You'd need a USB C PD solar charger. It would need to be able to switch to 9V mode in order to be able to charge the Muon via USB-C.
The best option is a 12V panel to VIN though like all devices you may need to adjust the maximum charge current in the bq24195 depending on the size of your panel. A 6V panel might work, but it's so close to the minimum voltage that it would likely only work when there's a lot of sun.
