If this is a good way, should I connect Load +/- of the the Sunny Buddy to the LiPo Battery Connector of the Electron? And then VIN of my electron to VIN of the pololu and VOUT of the pololu to the power of the ADS?
@jensfranke, just for the comparison of the two converters, you could use the 2564 just as well if you won’t need the shutdown pin.
It’ll become handy tho’ if you intend to use power saving modes on the Electron, since the efficiency of these converters goes down quite a bit when the current draw sinks.
But the foremost question here seems to be how to connect the converter to your setup.
Given this thread is about the Photon it might be better to move this question into it’s own thread or attach it to one of these https://community.particle.io/search?q=5v%20electron
Where should I move this for you?
Meanwhile, in order to answer your question, could you tell how you’re intending to power your Electron?
Will you have USB supply?
Will you have a LiPo connected?
Or both?
If using a LiPo without USB, how will you be charging your LiPo?
@ScruffR Thanks for explanation regarding 2564 vs. 2562. I think 2562 is better for my project.
Regarding my way to power the Electron: Currently I use a LiPo, but my prefered setup is with the Sunny Buddy from Sparkfun and this panel. Is this a good idea?
And sorry, please feel free to move my question to a better place.
It would be nice to get some help regarding the way how I plan to connect these components.
I start to rework on this project and it would be great to get the help of @ScruffR or @peekay123 to find the way how I need to connect Polou 25621 with the ADS 1231 to get 5V. In the end I want to power the whole system with the Sunny Buddy from Sparkfun. Thanks in advance for your help!
Your better off skipping the sun buddy and just charging the Electron and instead just use 5v solar panels and use code to limit the solar input from going below 4.8v which will prevent the solar panel from operating under its MPPT power point which is the whole point of the SunBuddy.
@jensfranke: Have you made any additional progress? I am in a similar situation. I was wondering if you continued with the Sunny Buddy or switched to a different solution.
