Anyone used this power supply CFM21M050 to power the Boron? Any issues?
I’ve never used it, but the specs look fine.
It has enough amperage and looks like it has big capacitors on it so it should work even without a LiPo battery, though if you plan on using the Boron 2G/3G without the LiPo you need to change some software settings in the PMIC because the modem may require more than the default input current limit. Set powerSourceMaxCurrent to 2000 instead of the default of 900.
Great. Thank you!
