Hello @ScruffR do you know how to port this Arduino library to Particle Boron environment?
Thanks in advance!
Thanks in advance!
In case @ScruffR is taking a well earned summer break - I can offer my advice:
in ADS7828.h
Replace
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
With
#include "Particle.h"
Then in ADS7828.cpp
Delete
#if ARDUINO >= 100
#else
#endif
#include <Wire.h>
You may need to #include "Particle.h" in its place
In function i2cread()
Replace
#if ARDUINO >= 100
return Wire.read();
#else
return Wire.receive();
#endif
With
return Wire.read();
In function i2cwrite()
Replace
#if ARDUINO >= 100
Wire.write((uint8_t)x);
#else
Wire.send(x);
#endif
With
Wire.write(uint8_t)x);
There are some changes to using Wire.beginTransmission() with OS 1.5.0 and later - but what is there should still work. Best that you compile using Particle Workbench.
Thanks a lot @armor! I will try it!
My advice is to use the ADS1115.
