Pololu Amis30543 Library
I am starting a project with this stepper motor driver. It requires SPI along with the normal stepping pins.
I haven’t start to fiddle, but any idea how difficult do you expect the import and use of this library would be, and would you have any recommendations to begin implementing it?
Link to Library:
I don’t think people appreciate having to search for the library in order to answer your request.
The least we could expect a link to the sources for that lib.
Yaix! You are totally correct and I apologize!
With a target >= 0.6.2 this library builds as is, so just give it a try.
@ScruffR Thank you for your help. Got the library working a bit ago! Worked flawlessly!
