pinMode not declared in current scope
Probably obvious to you guys, but…
in my ILI9341.h file, I have:
#define tftrspin    C1
In my ILI9341.cpp file, I have:
 pinMode(tftrspin,OUTPUT);
And the compiler complains about C1, pinMode and OUTPUT not being declared in current scope.
(I’m using a appropriated Macintosh, not my windoze pc.)
In a .cpp file, you must add:
#include "Particle.h"
it’s transparently added for .ino files, but for .cpp files you need to add it yourself.
If I’m making a library I add it at the top of its .h file.
If you get that error when including a .h file from someone else’s library, include Particle.h before including that library.
Oh! I suspected some subterfuge was going on!
Particle.h
