Hello to all.
I would like to incorporate the pid library with the Adaptive tunings example on a Photon.
In particular I need to replace the Output to a servo angle, just a little stumped on how to go about that.
Input will be analogRead and Output should be servo angle.
If setpoint is analogRead = 2048;
myServo.write(90); //minimum is 45degrees, maximum is 135degrees
Any assistance would be appreciated.
Not sure how this pertains to the PID library, but in order to map a reading in the range of 0…4095 to a range of 45…135 you’d just use angle = map(setpoint, 0, 4095, 45, 135).
Or simple algebra would do the trick just the same - after all that’s what map() uses internally
Thank you ScruffR.
I have tried to adapt that to the below example.
Getting a map overload error.
* PID Adaptive Tuning Example
* One of the benefits of the PID library is that you can
* change the tuning parameters at any time. this can be
* helpful if we want the controller to be agressive at some
* times, and conservative at others. in the example below
* we set the controller to use Conservative Tuning Parameters
* when we're near setpoint and more agressive Tuning
* Parameters when we're farther away.
#include "pid.h"
Servo myServo;
#define servoPin D1
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Define the aggressive and conservative Tuning Parameters
double aggKp=4, aggKi=0.2, aggKd=1;
double consKp=1, consKi=0.05, consKd=0.25;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, PID::DIRECT);
myServo.attach(servoPin);
myServo.write(90);
//initialize the variables we're linked to
Input = analogRead(0);
Setpoint = 2048;
//turn the PID on
myPID.SetMode(PID::AUTOMATIC);
Output = map(Setpoint, 0, 4096, 45, 135);
double gap = abs(Setpoint-Input); //distance away from setpoint
if(gap<10)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
else
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
myPID.Compute();
myServo.write(Output);
Since you are using a double for Setpoint your number literals also need to be floating point types otherwise the compiler wouldn’t know whether to make Setpoint an int or the 4 integers into double - hence the ambiguity error.
This will provide the required hint
Output = map(Setpoint, 0.0, 4095.0, 45.0, 135.0);
