Photon with fingerprint scanner and servo
Hi
I’m currently doing a project for my class, and I’m using an Arduino UNO with a jm-101 sensor for scanning fingerprints which, when fingerprints match it sends a signal to a servo motor to move from one position to another.
I want to translate my Arduino project into my photon for reducing size and as requirement for the class.
I’m having trouble communicating the sensor with the photon as it appears there’s no communication between the both of them.
Any help would be appreciate
here’s my original code:
#include<LiquidCrystal.h>
LiquidCrystal lcd(13,12,11,10,9,8);
#include <SoftwareSerial.h>
SoftwareSerial fingerPrint(2, 3);
#include<Servo.h>
Servo myServo;
int pos1=0;
#include <Adafruit_Fingerprint.h>
uint8_t id;
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&fingerPrint);
#define enroll 14
#define del 15
#define up 16
#define down 17
#define openLight 6
#define closeLight 7
#define servoPin 5
    delay(1000);
    myServo.attach(servoPin, 650, 2200);
    myServo.write(0);
    pinMode(enroll, INPUT_PULLUP);
    pinMode(up, INPUT_PULLUP);
    pinMode(down, INPUT_PULLUP);
    pinMode(del, INPUT_PULLUP);
    pinMode(openLight, OUTPUT);
    pinMode(closeLight, OUTPUT);
    lcd.begin(16,2);
    lcd.print("Security System");
    lcd.setCursor(0,1);
    lcd.print("by Finger Print");
    delay(2000);
    lcd.clear();
    lcd.print("Circuit Digest");
    lcd.setCursor(0,1);
    lcd.print("DJM PROJECT");
    delay(2000);
    finger.begin(57600);
    lcd.clear();
    lcd.print("Finding Module");
    lcd.setCursor(0,1);
    delay(1000);
    if (finger.verifyPassword())
      Serial.println("Found fingerprint sensor!");
      lcd.clear();
      lcd.print("Found Module ");
      delay(1000);
    else
    Serial.println("Did not find fingerprint sensor :(");
    lcd.clear();
    lcd.print("module not Found");
    lcd.setCursor(0,1);
    lcd.print("Check Connections");
    while (1);
 lcd.setCursor(0,0);
 lcd.print("Press UP/Down ");
 lcd.setCursor(0,1);
 lcd.print("to start System");
 digitalWrite(closeLight, HIGH);
 if(digitalRead(up)==0 || digitalRead(down)==0)
  for(int i=0;i<5;i++)
    lcd.clear();
    lcd.print("Place Finger");
    delay(2000);
    int result=getFingerprintIDez();
    if(result>=0)
        digitalWrite(openLight, HIGH);
        digitalWrite(closeLight, LOW);
        lcd.clear();
        lcd.print("Allowed");
        lcd.setCursor(0,1);
        lcd.print("Gate Opened   ");
        myServo.write(90);
        delay(5000);
        myServo.write(0);
        digitalWrite(openLight, LOW);
        lcd.setCursor(0,1);
        lcd.print("Gate Closed   ");
        return;
 checkKeys();
 delay(1000);
void checkKeys()
   if(digitalRead(enroll) == 0)
    lcd.clear();
    lcd.print("Please Wait");
    delay(1000);
    while(digitalRead(enroll) == 0);
    Enroll();
   else if(digitalRead(del) == 0)
    lcd.clear();
    delay(1000);
    delet();
void Enroll()
   int count=0;
   lcd.clear();
   lcd.print("Enroll Finger    ");
   lcd.setCursor(0,1);
   lcd.print("Location:");
   while(1)
     lcd.setCursor(9,1);
     lcd.print(count);
     if(digitalRead(up) == 0)
       count++;
       if(count>25)
       count=0;
       delay(500);
     else if(digitalRead(down) == 0)
       count--;
       if(count<0)
       count=25;
       delay(500);
          id=count;
          getFingerprintEnroll();
          return;
       else if(digitalRead(enroll) == 0)
          return;
void delet()
   int count=0;
   lcd.clear();
   lcd.print("Delete Finger    ");
   lcd.setCursor(0,1);
   while(1)
     lcd.setCursor(9,1);
     lcd.print(count);
       count++;
       if(count>25)
       count=0;
       delay(500);
       count--;
       if(count<0)
       count=25;
       delay(500);
          id=count;
          deleteFingerprint(id);
          return;
          return;
void serv()
  for(pos1 = 180; pos1>=1; pos1-=1)
    myServo.write(pos1);
    delay(2); // tiempo que tarda en ir a la siguiente posicion
  delay(2000);
  for(pos1 = 0; pos1 <180; pos1+=1)
 delay(0.5); //tiempo que tarda en retroceder
uint8_t getFingerprintEnroll()
  int p = -1;
  lcd.clear();
  lcd.print("finger ID:");
  lcd.print(id);
  lcd.setCursor(0,1);
  delay(2000);
  while (p != FINGERPRINT_OK)
    p = finger.getImage();
    switch (p)
    case FINGERPRINT_OK:
      Serial.println("Image taken");
      lcd.clear();
      lcd.print("Image taken");
      break;
    case FINGERPRINT_NOFINGER:
      Serial.println("No Finger");
      lcd.clear();
      lcd.print("No Finger");
      break;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      lcd.clear();
      lcd.print("Comm Error");
      break;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      lcd.clear();
      lcd.print("Imaging Error");
      break;
    default:
      Serial.println("Unknown error");
       lcd.clear();
      lcd.print("Unknown Error");
      break;
  // OK success!
  p = finger.image2Tz(1);
  switch (p) {
      Serial.println("Image converted");
      lcd.clear();
      lcd.print("Image converted");
      break;
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
       lcd.clear();
       lcd.print("Image too messy");
      return p;
      lcd.clear();
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      lcd.clear();
      lcd.print("Feature Not Found");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      lcd.clear();
      return p;
    default:
      lcd.clear();
      return p;
  Serial.println("Remove finger");
  lcd.clear();
  lcd.print("Remove Finger");
  delay(2000);
  p = 0;
  while (p != FINGERPRINT_NOFINGER) {
  Serial.print("ID "); Serial.println(id);
  p = -1;
  Serial.println("Place same finger again");
   lcd.clear();
      lcd.setCursor(0,1);
      lcd.print("   Again");
  while (p != FINGERPRINT_OK) {
    switch (p) {
      break;
      Serial.print(".");
      break;
      break;
      break;
    default:
      return;
  // OK success!
  p = finger.image2Tz(2);
  switch (p) {
      break;
      return p;
      return p;
      return p;
      return p;
    default:
      return p;
  // OK converted!
  Serial.print("Creating model for #");  Serial.println(id);
  p = finger.createModel();
  if (p == FINGERPRINT_OK) {
    Serial.println("Prints matched!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_ENROLLMISMATCH) {
    Serial.println("Fingerprints did not match");
    return p;
  } else {
    return p;
  p = finger.storeModel(id);
    Serial.println("Stored!");
    lcd.clear();
    lcd.print("Stored!");
    delay(2000);
    return p;
  } else if (p == FINGERPRINT_BADLOCATION) {
    Serial.println("Could not store in that location");
    return p;
  } else if (p == FINGERPRINT_FLASHERR) {
    Serial.println("Error writing to flash");
    return p;
  else {
    return p;
int getFingerprintIDez()
  uint8_t p = finger.getImage();
  if (p != FINGERPRINT_OK)
  return -1;
  p = finger.image2Tz();
  return -1;
  p = finger.fingerFastSearch();
   lcd.clear();
   lcd.print("Finger Not Found");
   lcd.setCursor(0,1);
   lcd.print("Try Later");
   delay(2000);
  return -1;
  // found a match!
  Serial.print("Found ID #");
  Serial.print(finger.fingerID);
  return finger.fingerID;
uint8_t deleteFingerprint(uint8_t id)
  uint8_t p = -1;
  lcd.clear();
  lcd.print("Please wait");
  p = finger.deleteModel(id);
    Serial.println("Deleted!");
    lcd.clear();
    lcd.print("Figer Deleted");
    lcd.setCursor(0,1);
    lcd.print("Successfully");
    delay(1000);
  else
    Serial.print("Something Wrong");
    lcd.clear();
    lcd.print("Something Wrong");
    lcd.setCursor(0,1);
    lcd.print("Try Again Later");
    delay(2000);
    return p;
It would make more sense to (also) show the code you are running on the Photon.
On the Photon I’d rather use hardware Serial1 instead of SoftwareSerial.
Also doublecheck that your external hardware does work with 3.3V signals, otherwise you may need to add level shifting.
Also what pins are you using on the Photon?
Hi, I currently just put the same part of the sensor code in the photon to look which commands are not compatible and reassign the pins as
Photon - - >sensor
Tx-------------Rx
Rx------------Tx
Gnd - - - - - - Gnd
Vin-----------V
