Photon stopped publishing to console and cannot reconnect
Hi: I was recently catching up on some hobby devices I have connected and discovered they stopped publishing to the console back on January 2, 2023? I started reading troubleshooting articles and testing old code etc. but cannot get any of them to publish data to the console like before. I checked that I have delays for frequency, updated firmware, and I am not maxed out on the sandbox data usage. Did something change in publishing requirements for photon (1.0) around this time?
Here is a snip of some of the basic code I have been using:
  Blynk.begin(auth);
  // Set variable
  Particle.variable("i2cdevice","ADXL345");
  Particle.variable("xAccl",xAccl);
  Particle.variable("yAccl",yAccl);
  Particle.variable("zAccl",zAccl);
  // Initialise I2C communication as MASTER
  Wire.begin();
  // Initialise serial communication, set baud rate = 9600
  // Start I2C transmission
  Wire.beginTransmission(Addr);
  // Select bandwidth rate register
  Wire.write(0x2C);
  // Select output data rate = 100 Hz
  Wire.write(0x0A);
  // Stop I2C Transmission
  Wire.endTransmission();
  // Select power control register
  Wire.write(0x2D);
  // Select auto sleep disable
  Wire.write(0x08);
  // Stop I2C transmission
  // Select data format register
  Wire.write(0x31);
  // Select full resolution, +/-2g (0X08) , for 16g it shoudl be (0x0B)
  Wire.write(0x0B);
  // End I2C transmission
  delay(300);
  ///Blynk.Run();
  unsigned int data[6];
  for(int i = 0; i < 6; i++) {
    // Select data register
    Wire.write((50+i));
    // Request 1 byte of data from the device
    Wire.requestFrom(Addr,1);
    // Read 6 bytes of data
    // xAccl lsb, xAccl msb, yAccl lsb, yAccl msb, zAccl lsb, zAccl msb
    if(Wire.available()==1) {
      data[i] = Wire.read();
    delay(300);
  // Convert the data to 10-bits
  int xAccl = (((data[1] & 0x03) * 256) + data[0]);
  if(xAccl > 511) {
    xAccl -= 1024;
  int yAccl = (((data[3] & 0x03) * 256) + data[2]);
  if(yAccl > 511) {
    yAccl -= 1024;
  int zAccl = (((data[5] & 0x03) * 256) + data[4]);
  if(zAccl > 511) {
    zAccl -= 1024;
  //convert to G's************************************
  ///xg1 = 4/(1023*xAccl) + (2/1023);
  ///yg1 = 4/(1023*yAccl) + (2/1023);
  ///zg1 = 4/(1023*zAccl) + (2/1023);
  //convert to G's*************************************
  // Output data to dashboard
  Particle.publish("Acceleration in X-Axis is :", String(xAccl));
  Particle.publish("Acceleration in Y-Axis is :", String(yAccl));
  Particle.publish("Acceleration in Z-Axis is :", String(zAccl));
Hi and welcome to the community!
It could be that blynk is the issue there, since the old blynk (which you may potentially be using) has been deprecated:
What happens if you comment out blynk.begin() and maybe other blynk calls to find out if it is the case?
Cheers
Have you made sure that your Particle.publish() calls don't run into the rate limit?
Additionally, is it intentional to have Blynk.run() commented out?
Hi: I took the advice provided to remove the old Blynk code and that fixed it. My sensors are now reporting on the console. Thanks for the help.
