Hello
I am new to Particle and have to say I like the Hardware. I have previously used the Wemos D1 mini for my projects and thought I would give Particle a try. The problem I am having is I had my sketch working perfect with the D1 mini but on the Photon when internet is down or when Wifi is down the sketch hangs. This is a problem because the photon will be controlling an egg Incubator so it’s critical for the sketch to continue to run even if connection is lost. Im hatching eggs worth $400 a dozen and would really suck if temp or Humidity drops too low because of a wifi or cloud disconnect that Im unaware of. The way I had it setup on the D1 is it would check the connection every minute to see if wifi was connected if it was not it would try to connect 15 times and after the 15th sketch would break and continue to run my code. Im new to coding so I am not sure how to accomplish this on the particle devices. I have seen something in the docs about Semi Automatic mode but from what I see you have to push a button for it to connect but that is an issue because if i go to work or away for a couple days I wont be there to push the button. I would like it to check the state of the connection automatically and try to reconnect if Internet connection comes back just like on the D1 mini. Here is the piece code from the D1 mini that checks the connection. I would like to accomplish the exact same thing with the Photon and Boron.
// Debug console
timer.setInterval(60000L, connectWiFi);
timer.setInterval(65000L, CheckConnection);
if (Blynk.connected()) {
Blynk.run();
timer.run();
void connectWiFi()
BLYNK_LOG("Connecting to %s", ssid);
if (pass && strlen(pass))
WiFi.begin(ssid, pass);
else {
WiFi.begin(ssid);
//if (WiFi.status() == WL_CONNECTED) {
Serial.print("Wifi Connected");
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
tries++;
if (tries > 15)
//offline
break;
void CheckConnection()
{ // check every 11s if connected to Blynk server
if (!Blynk.connected()) {
Serial.println("Not connected to Blynk server");
//Blynk.config(auth, IP, 80);
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
Blynk.connect(); // try to connect to server with default timeout
else
Serial.println("Connected to Blynk server");
