What is the typical power consumption for Photon’s RTC / VBAT?
(I know I’ve seen some numbers in other discussions, but can’t seem to find it.)
The datasheet only lists the max but doesn’t have values for minimum or typical:
| Parameter | Symbol | Min | Typ | Max | Unit |
| Supply Input Current (VBAT) | IVBAT | x | x | 19 | uA |
Also, anybody knows what factors would cause the current to be higher/lower?
The supplied voltage would make it go lower… but I don’t really know by how much.
I suspect that the 19uA goes with the max allowed voltage on that pin ( 3.6v if I recall correctly ).
it might be a real pain to measure the actual current… since it’s so low… maybe Dave’s micro current meter would do it ?
