Photon powered from a 12v relay module.... why is it working?
Hello,
I’m using a 12v relay module from SainSmart ( https://www.sainsmart.com/collections/relays/products/16-channel-12v-relay-module ) with a pin expander MCP23007 and my Particle Photon.
The MCP23007 is powered thanks to the VIN from the Photon.
So you have : RELAY <—> MCP23007 <—> Particle Photon
I have discovered that I don’t need to power my Photon with the USB when the relay is powered by a 12v arrival. And everything is surprisingly working well…
Why ? Is it ok for the Photon on the long term ?
By the way, do you know any other relay module with 16 channels ?
Julien
@julienfoodgie, the relay board has its own 5v regulator which you are connecting to Vin of the Photon. This is why USB power is not required. :wink:
thanks for your quick answer.
What do you think about this relay board ? Are there any better (bigger) boards ?
Thanks :slight_smile:
@julienfoodgie, it looks good. However, ControlEverything has 24 and 32 relay boards that are I2C controlled if you are looking for more relays.
@peekay123 thanks for your help. I followed your advice and it works very well.
I bought an other 8 relays board and want to connect it to my master board but I don't understand the address jumpers. Do you have any idea ? I've opened a topic on the matter:
