Hi guys
I'm trying to make my photon run a code without the need to connect to wifi, I tried :
SYSTEM_MODE(SEMI_AUTOMATIC);
boolean connectToCloud = false;
at the top of my code but, I get the following error
../wiring/inc/spark_wiring_system.h:458:55: redefinition of 'SystemClass SystemMode'
this is the raw:
Processing commov_rx.ino
Checking library LiquidCrystal...
Checking library Adafruit_MCP23017...
Checking library neopixel...
Checking library RFM69-Particle...
Installing library neopixel 1.0.0 to lib/neopixel ...
Installing library RFM69-Particle 0.0.5 to lib/RFM69-Particle ...
Installing library LiquidCrystal 0.0.3 to lib/LiquidCrystal ...
Installing library Adafruit_MCP23017 1.0.2 to lib/Adafruit_MCP23017 ...
Library neopixel 1.0.0 installed.
Library LiquidCrystal 0.0.3 installed.
Library Adafruit_MCP23017 1.0.2 installed.
Library RFM69-Particle 0.0.5 installed.
make -C ../modules/photon/user-part all
make[1]: Entering directory '/firmware/modules/photon/user-part'
make -C ../../../user
make[2]: Entering directory '/firmware/user'
Building cpp file: src/commov_rx.cpp
Invoking: ARM GCC CPP Compiler
mkdir -p ../build/target/user/platform-6-msrc/
arm-none-eabi-gcc -DSTM32_DEVICE -DSTM32F2XX -DPLATFORM_THREADING=1 -DPLATFORM_ID=6 -DPLATFORM_NAME=photon -DUSBD_VID_SPARK=0x2B04 -DUSBD_PID_DFU=0xD006 -DUSBD_PID_CDC=0xC006 -DSPARK_PLATFORM -g3 -gdwarf-2 -Os -mcpu=cortex-m3 -mthumb -DINCLUDE_PLATFORM=1 -DPRODUCT_ID=6 -DPRODUCT_FIRMWARE_VERSION=65535 -DUSE_STDPERIPH_DRIVER -DDFU_BUILD_ENABLE -DSYSTEM_VERSION_STRING=1.4.3 -DRELEASE_BUILD -I./inc -I../wiring/inc -I../system/inc -I../third_party/miniz/miniz -I../services/inc -I../third_party/nanopb/nanopb -I../communication/inc -I../hal/inc -I../hal/shared -I../hal/src/photon -I../hal/src/stm32f2xx -I../hal/src/stm32 -I../hal/src/photon/api -I../hal/src/photon/include -I../hal/src/photon/wiced/security/BESL/host/WICED/ -I../hal/src/photon/wiced/security/BESL/include -I../hal/src/photon/wiced/security/BESL -I../hal/src/photon/wiced/security/BESL/crypto -I../hal/src/photon/wiced/WWD/include/ -I../hal/src/photon/wiced/platform/include/ -I../hal/src/photon/wiced/platform/GCC/ -I../hal/src/photon/wiced/security/BESL/supplicant/ -I../hal/src/photon/libraries/crypto -I../hal/src/photon/libraries/daemons/DNS_redirect -I../platform/shared/inc -I../platform/MCU/STM32F2xx/STM32_USB_Host_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_OTG_Driver/inc -I../platform/MCU/STM32F2xx/STM32_StdPeriph_Driver/inc -I../platform/MCU/STM32F2xx/STM32_USB_Device_Driver/inc -I../platform/MCU/STM32F2xx/SPARK_Firmware_Driver/inc -I../platform/MCU/shared/STM32/inc -I../platform/MCU/STM32F2xx/CMSIS/Include -I../platform/MCU/STM32F2xx/CMSIS/Device/ST/Include -I../dynalib/inc -Isrc -I./libraries -Ilib/LiquidCrystal/src -Ilib/RFM69-Particle/src -Ilib/Adafruit_MCP23017/src -Ilib/neopixel/src -I. -MD -MP -MF ../build/target/user/platform-6-msrc/commov_rx.o.d -ffunction-sections -fdata-sections -Wall -Wno-switch -Wno-error=deprecated-declarations -fmessage-length=0 -fno-strict-aliasing -DSPARK=1 -DPARTICLE=1 -Wundef -DSTART_DFU_FLASHER_SERIAL_SPEED=14400 -DSTART_YMODEM_FLASHER_SERIAL_SPEED=28800 -DBOOTLOADER_SDK_3_3_0_PARTICLE -DPARTICLE_DCT_COMPATIBILITY -DSPARK_PLATFORM_NET=BCM9WCDUSI09 -fno-builtin-malloc -fno-builtin-free -fno-builtin-realloc -DLOG_INCLUDE_SOURCE_INFO=1 -DPARTICLE_USER_MODULE -DUSER_FIRMWARE_IMAGE_SIZE=0x20000 -DUSER_FIRMWARE_IMAGE_LOCATION=0x80A0000 -DMODULAR_FIRMWARE=1 -DMODULE_VERSION=6 -DMODULE_FUNCTION=5 -DMODULE_INDEX=1 -DMODULE_DEPENDENCY=4,2,1405 -DMODULE_DEPENDENCY2=0,0,0 -D_WINSOCK_H -D_GNU_SOURCE -DLOG_MODULE_CATEGORY="\"app\"" -fno-exceptions -fno-rtti -fcheck-new -std=gnu++14 -c -o ../build/target/user/platform-6-msrc/commov_rx.o src/commov_rx.cpp
In file included from ../wiring/inc/spark_wiring.h:50:0,
from ./inc/application.h:40,
from src/commov_rx.cpp:1:
../wiring/inc/spark_wiring_system.h:458:55: error: redefinition of 'SystemClass SystemMode'
#define SYSTEM_MODE(mode) SystemClass SystemMode(mode);
commov_rx.ino:62:1: note: in expansion of macro 'SYSTEM_MODE'
../wiring/inc/spark_wiring_system.h:458:40: note: 'SystemClass SystemMode' previously declared here
commov_rx.ino:13:1: note: in expansion of macro 'SYSTEM_MODE'
../build/module.mk:277: recipe for target '../build/target/user/platform-6-msrc/commov_rx.o' failed
make[2]: *** [../build/target/user/platform-6-msrc/commov_rx.o] Error 1
make[2]: Leaving directory '/firmware/user'
../../../build/recurse.mk:11: recipe for target 'user' failed
make[1]: *** [user] Error 2
make[1]: Leaving directory '/firmware/modules/photon/user-part'
../build/recurse.mk:11: recipe for target 'modules/photon/user-part' failed
make: *** [modules/photon/user-part] Error 2
here is my code:
any ideas of how to solve this?
Thank you!
