Photon not able to be powered by sparkfun weather shield with latest firmware
I have not been able to power the photons using weather shield which are updated to firmware 0.6.2. I get a steady white light on power up. Earlier version of firmware works fine. Is there a way to change the photon firmware back to the earlier version?
You can compile the weather shield firmware using an earlier system firmware version by setting it for the Photon under the devices Tab in Build IDE.
@pathin have you had any success? I am running into the same problem, but I can’t get mine working regardless of the firmware I use to compile the code.
I would greatly appreciate any help you could provide!
