Thanks guys. I guess I should have been more clear. @ScruffR, you’re correct, there is another board I have with the same address but not part of this circuit.
Here’s the full code, I was trying to save people from having to read the entire code set, I figured it was the wiring. Please find the full code below.
Lastly, I tried pull up resistors on the SCL/SDA but as you mentioned the MPL board already has the resistor in place as far as I can tell.
#include <application.h>
#include <spark_wiring_i2c.h>
// MPL3115A2 I2C address is 0x60(96)
#define Addr 0x60
double cTemp = 0.0, fTemp = 0.0, pressure = 0.0, altitude = 0.0;
int temp = 0, tHeight = 0;
long pres = 0;
// Set variable
Particle.variable("i2cdevice", "MPL3115A2");
Particle.variable("cTemp", cTemp);
Particle.variable("pressure", pressure);
Particle.variable("altitude", altitude);
// Initialise I2C communication
Wire.begin();
// Initialise Serial Communication, set baud rate = 9600
// Start I2C transmission
Wire.beginTransmission(Addr);
// Select control register
Wire.write(0x26);
// Active mode, OSR = 128, altimeter mode
Wire.write(0xB9);
// Stop I2C transmission
Wire.endTransmission();
// Select data configuration register
Wire.write(0x13);
// Data ready event enabled for altitude, pressure, temperature
Wire.write(0x07);
delay(300);
unsigned int data[6];
Wire.write(0x26);
Wire.write(0xB9);
delay(1000);
// Select data register
Wire.write(0x00);
// Request 6 bytes of data
Wire.requestFrom(Addr, 6);
// Read 6 bytes of data from address 0x00(00)
// status, tHeight msb1, tHeight msb, tHeight lsb, temp msb, temp lsb
if(Wire.available() == 6)
data[0] = Wire.read();
data[1] = Wire.read();
data[2] = Wire.read();
data[3] = Wire.read();
data[4] = Wire.read();
data[5] = Wire.read();
Serial.println(data[4]);
// Convert the data to 20-bits
tHeight = ((((long)data[1] * (long)65536) + (data[2] * 256) + (data[3] & 0xF0)) / 16);
temp = ((data[4] * 256) + (data[5] & 0xF0)) / 16;
altitude = tHeight / 16.0;
cTemp = (temp / 16.0);
fTemp = cTemp * 1.8 + 32;
Wire.write(0x26);
// Active mode, OSR = 128, barometer mode
Wire.write(0x39);
Wire.write(0x00);
delay(1000);
// Request 4 bytes of data
Wire.requestFrom(Addr, 4);
// Read 4 bytes of data
// status, pres msb1, pres msb, pres lsb
if(Wire.available() == 4)
pres = (((long)data[1] * (long)65536) + (data[2] * 256) + (data[3] & 0xF0)) / 16;
pressure = (pres / 4.0) / 1000.0;
// Output data to dashboard
Particle.publish("Altitude :", String(altitude));
delay(1000);
Particle.publish("Pressure :", String(pressure));
delay(1000);
Particle.publish("Temperature in Celsius :", String(cTemp));
Serial.println(cTemp);
delay(1000);
Particle.publish("Temperature in Fahrenheit :", String(fTemp));
delay(1000);
