Photon Flashing Cyan After Interval
Having issues with Photon going offline after a certain interval. It seems to have corresponded with adding new firmware which included POST to data.sparkfun.com. Though not 100% that is the cause. Code seems to work fine for a while and then Photon goes to flashing cyan and stops running. If I remove the POST section it stays on and if I increase the interval it appears to last longer. No idea why however?
#include "DHT.h"
#include "SparkFun-Spark-Phant/SparkFun-Spark-Phant.h"
#define DHTPIN          D4
#define DHTTYPE         DHT22
#define DELAY           5000
//Setup DHT Sensor
    DHT dht(DHTPIN, DHTTYPE);
    int temperature = 0;
    int humidity = 0;
//Setup data.sparkfun.com
const char server[] = "data.sparkfun.com"; // Phant destination server
const char publicKey[] = "MY_KEY"; // Phant public key
const char privateKey[] = "MY_KEY"; // Phant private key
Phant phant(server, publicKey, privateKey); // Create a Phant object
//Global variable for data.sparkfun.com POST
int steptime = 0;
    Serial.begin(115200);
    dht.begin();
    // Particle Functions
    Spark.function("gettmp", getTemperature);
    Spark.function("gethmd", getHumidity);
    // Get temperature and humidity
    temperature = (int)dht.readTemperature(true);
    humidity = (int)dht.readHumidity();
    //Execute data.sparkfun.com POST every 10 min
    steptime++;
    if(steptime == 120){
        postToPhant();
        steptime = 0;
    //Delay till next loop
    delay(DELAY);
int postToPhant()
    phant.add("temp", temperature);
    phant.add("humidity", humidity);
    TCPClient client;
    char response[512];
    int i = 0;
    int retVal = 0;
    if (client.connect(server, 80))
        Serial.println("Posting!");
        client.print(phant.post());
        delay(1000);
        while (client.available())
            char c = client.read();
            //Serial.print(c);
            if (i < 512)
                response[i++] = c;
        if (strstr(response, "200 OK"))
            Serial.println("Post success!");
            retVal = 1;
        else if (strstr(response, "400 Bad Request"))
            Serial.println("Bad request");
            retVal = -1;
        else
            retVal = -2;
    else
        Serial.println("connection failed");
        retVal = -3;
    client.stop();
    return retVal;
Although I’m not sure if it’s connected to the issues you’re seeing, Might I recommend that you use the Piettetech library for the DHT. It is known to be highly reliable, whereas other have displayed various problems. Could be that the library is causing issues.
Thanks for the suggestion. I actually had this running for several weeks without exporting the data to spark so not sure the DHT is the issue but worth a try. One question I haven’t seen answered anywhere is what a flashing cyan actually means. Docs say its server handshake, but that doesn’t really make sense in my case.
The code that really seems to kill it is the section:
steptime++; if(steptime == 120){ postToPhant(); steptime = 0; }
But it works fine for the first few cycles.
Rapid flashing cyan was introduced just recently (I think with 0.4.4), I’ll try to find the description (when introduced), but it should be cloud handshake as you said.
Why would you say it doesn’t make sense in your case?
If your code (or other circumstances) kill the cloud connection, it will (usually) try to reestablish and has to go through all the hookup-blinks.
And the big part not shown in your 5-liner above is postToPhant() implementation. Anything in there could trip the cloud, especially if there are long running remote tasks,
Maybe adding a Particle.process() and a timeout in here
            //Serial.print(c);
            if (i < 512)
                response[i++] = c;
might break out of a potentially long running loop and at least service the cloud often enough.
Thanks for suggestions, I will give this a try and see if there are any changes. I did include the postToPhant() in the original post, just didn’t want to duplicate, and that function does now include your last suggestion.
int postToPhant()
    TCPClient client;
    char response[512];
    int i = 0;
    int retVal = 0;
        delay(1000);
            //Serial.print(c);
            if (i < 512)
                response[i++] = c;
            retVal = 1;
            retVal = -1;
        else
            retVal = -2;
    else
        retVal = -3;
    client.stop();
    return retVal;
Can’t see my suggestions incorporated in there tho’
I thought like so
        uint32_t msTimeout = millis();
        while (client.available() && (millis() - msTimeout < 3000))
            //Serial.print(c);
            if (i < 512)
                response[i++] = c;
            Particle.process();
Ya, sorry didn’t include on my post. Will give it a try tonight though. THANKS!
ScruffR, that Particle.process() suggestion seems to have been the ticket. Going 24hrs strong. THANKS!
