Here is my central heating system automation code, yesterday i tried to add MQTT support but when i send MQTT “ON” command particle crashes.
Maybe there’s some simple mistake that someone can spot?
when i send on/off/auto command from particle console: int MobileSwitch(String command)
then everything works (has been working for years).
SYSTEM_THREAD(ENABLED);
#include "mqtt.h"
#include "analogSmooth.h"
#include <LiquidCrystal_I2C_Spark.h>
#include <TimeAlarms.h>
#undef now();
float callback(char* topic, byte* payload, unsigned int length);
byte server[] = { 192,168,1,223 };
MQTT client(server, 1883, callback);
String writeAPIKey = "XXX";
String channelID = "XXX";
TCPClient Xclient;
int ledRed = A4; // A4 -- A0 if ON then indicates that there is 230V present and boiler pump is OFF
int ledGreen = A5; // A5 -- A1 is ON then boiler pump is ON
int radikatemp = A6; //A6 --A2
int toatemp = A0; //A0 -- A3
int pliiditemp = A1; //A1 -- A4
int pliidiveetemp = A2; //A2 -- A5
int xtemp = A3; //A3 --A6
int relayRadiator = D2; //relay to turn ON/OFF radiator pump
int relayBoiler = D3; // relay to turn ON/OFF boiler pump.
int c = 0;
int d = 0;
int aeg = 0;
int secs = 0;
int mins=0;
int hours=0;
LiquidCrystal_I2C *lcd;
//UDP UDPClient;
String timeStr;
AnalogSmooth as100 = AnalogSmooth(10);
AnalogSmooth as101 = AnalogSmooth(30);
AnalogSmooth as102 = AnalogSmooth(10);
AnalogSmooth as103 = AnalogSmooth(10);
float radikaC = 0.0;
float toaC = 0.0;
float pliidiC = 0.0;
float pliidiveeC = 0.0;
float xtempC = 0.0;
int toggleDelay = 5;
int toggleLCDState = 1;
int previousNow = 0;
int previousNow2 = 0;
int ForceState = 0;
float callback(char* topic, byte* payload, unsigned int length) {
char p[length + 1];
memcpy(p, payload, length);
p[length] = NULL;
Serial.println("callback...");
if (!strcmp(p, "ON")){
if(radikaC > 39){
previousNow2 = Time.now();
ForceState = 1;
if (!strcmp(p, "OFF")){
ForceState = -1;
if (!strcmp(p, "AUTO")){
ForceState = 0;
void setup(){
// Particle.function("Radikapump",MobileSwitch);
Time.zone(+2);
Alarm.alarmRepeat(8,30,0, MorningAlarm); // 8:30am every day
Alarm.timerRepeat(400, Repeats2);// timer for every 400 seconds
Alarm.timerOnce(10, OnceOnly); // called once after 10 seconds
lcd = new LiquidCrystal_I2C(0x27, 20, 4); // set the LCD address to 0x20 for a 16x2 //SparkCore bug, address is actually 27 but shifted (0x27*2)
lcd->init(); // initialize the lcd
lcd->backlight();
// lcd->noBacklight();
lcd->clear();
pinMode(radikatemp, INPUT_PULLDOWN);
pinMode(toatemp, INPUT_PULLDOWN);
pinMode(pliiditemp, INPUT_PULLDOWN);
pinMode(pliidiveetemp, INPUT_PULLDOWN);
pinMode(xtemp, INPUT_PULLDOWN);
pinMode(ledRed, OUTPUT);
pinMode(ledGreen, OUTPUT);
pinMode(relayRadiator, OUTPUT);
pinMode(relayBoiler, OUTPUT);
digitalWrite(relayRadiator, LOW);
digitalWrite(relayBoiler, LOW);
analogWrite(ledRed,150);
void loop(){
if(!client.isConnected()){
client.connect("centralheating");
// Serial.println("Connecting to MQTT...");
client.subscribe("staatus");
if(client.isConnected()){
client.loop();
// Serial.println("Connected to MQTT.");
radikaC = (as100.analogReadSmooth(radikatemp) * 3.3) / 4095*100; //getting the voltage reading from the temperature sensor
toaC = (as101.analogReadSmooth(toatemp) * 3.3) / 4095*100 - 0.5;
pliidiC = (as102.analogReadSmooth(pliiditemp) * 3.3) / 4095*200;
pliidiveeC = (analogRead(pliidiveetemp) * 3.3) / 4095*100;
xtempC = (analogRead(xtemp) * 3.3) / 4095*100;
if(Time.now() - previousNow > toggleDelay) {
previousNow = Time.now();
lcd->clear();
if (toggleLCDState == 1){
toggleLCDState = 0;
toggleDelay = 3;
else{
toggleLCDState = 1;
toggleDelay = 10;
if(Time.now() - previousNow2 > 7200) {
ForceState = 0;
lcd->clear();
if(toggleLCDState == 1){
lcd->setCursor(1,0);
lcd->print("Korsten");
lcd->setCursor(11,0);
lcd->print(pliidiC, 1);
lcd->print(" ");
lcd->setCursor(1,1);
lcd->print("Radikasse");
lcd->setCursor(11,1);
lcd->print(radikaC, 1);
lcd->print(" ");
lcd->setCursor(1,2);
lcd->print("Toatemp");
lcd->setCursor(11,2);
lcd->print(toaC, 1);
lcd->print(" ");
lcd->setCursor(1,3);
lcd->print("Pliita");
lcd->setCursor(11,3);
lcd->print(pliidiveeC, 1);
lcd->print(" ");
else if(toggleLCDState == 0){
digitalClockDisplay();
if(ForceState != 0){
secs = 14400 - (Time.now() - previousNow2); //
mins=secs/60; //convert seconds to minutes
hours=mins/60; //convert minutes to hours
secs=secs-(mins*60); //subtract the coverted seconds to minutes in order to display 59 secs max
mins=mins-(hours*60); //subtract the coverted minutes to hours in order to display 59 minutes max
lcd->setCursor(3,2);
lcd->print("Forced state: ");
lcd->setCursor(6,3);
if(hours<10) lcd->print('0');
lcd->print(hours);
lcd->print(":");
if(mins<10) lcd->print('0');
lcd->print(mins);
lcd->print(":");
if(secs<10) lcd->print('0');
lcd->print(secs);
if (toaC > 23.6){
ForceState = -1;
c = tempkontroll(radikaC, toaC, c, aeg, pliidiveeC);
d = tempkontroll2(pliidiC, pliidiveeC, d);
Taustavalgus();
Alarm.delay(900);
void Taustavalgus(){
if(Time.hour()<8 || Time.hour()>20){
lcd->noBacklight();
else{
lcd->backlight();
void ThingSpeakUpdate(String tsData)
Serial.println("Date string: " + tsData);
Serial.println("...Connecting to Thingspeak");
// Connecting and sending data to Thingspeak
if(Xclient.connect("api.thingspeak.com", 80))
Serial.println("...Connection succesful, updating datastreams");
Xclient.print("POST /update HTTP/1.1\n");
Xclient.print("Host: api.thingspeak.com\n");
Xclient.print("Connection: close\n");
Xclient.print("X-THINGSPEAKAPIKEY: "+writeAPIKey+"\n");
Xclient.print("Content-Type: application/x-www-form-urlencoded\n");
Xclient.print("Content-Length: ");
Xclient.print(tsData.length());
Xclient.print("\n\n");
Xclient.println(tsData); //the ""ln" is important here.
// This delay is pivitol without it the TCP client will often close before the data is fully sent
delay(250);
Serial.println("Thingspeak update sent.");
else{
Serial.println("Unable to connect to Thingspeak.");
if(!Xclient.connected()){
Xclient.stop();
Xclient.flush();
Xclient.stop();
int tempkontroll(float radikaC, float toaC, int c, int aeg, float pliidiveeC) {
aeg =Time.hour()*60+Time.minute();
if((toaC < 20.7 && radikaC > 39 && c == 0 && aeg < 1290 && aeg > 360 && ForceState == 0) || (ForceState == 1)) {
c = 1;
digitalWrite(relayRadiator, HIGH); //paneb relee "HIGH" asendisse
if((radikaC > 84 || pliidiveeC > 84) && c == 0) {
c = 1;
Alarm.delay(100);
else if((((toaC > 21.4 || radikaC < 37) && c == 1 && radikaC < 88 && ForceState == 0) || (aeg > 1290 && radikaC < 88 && ForceState == 0)) || (ForceState == -1 && radikaC < 88) ) {
c = 0;
digitalWrite(relayRadiator, LOW); //paneb relee "LOW" asendisse
return c;
int tempkontroll2(float pliidiC, float pliidiveeC, int d) {
if((pliidiC > 90 || pliidiveeC > 80) && d == 0) {
d = 1;
digitalWrite(relayBoiler, HIGH); //paneb relee "HIGH" asendisse
analogWrite(ledRed,0);
analogWrite(ledGreen,150);
else if(pliidiC < 85 && pliidiveeC <79 && d == 1) {
d = 0;
digitalWrite(relayBoiler, LOW); //paneb relee "LOW" asendisse
analogWrite(ledGreen,0);
return d;
void MorningAlarm(){
Spark.syncTime();
if (isDST() == 1){
Time.beginDST();
else {
Time.endDST();
void Repeats2(){
// client.publish("centralheating/",String(celsius, 1));
if(Spark.connected())
ThingSpeakUpdate("field1="+String(toaC)+"&field2="+String(radikaC)+"&field3="+String(pliidiC)+"&field4="+String(pliidiveeC)+"&field6="+String(c)+"&field7="+String(d));
void OnceOnly(){
Spark.syncTime();
if (isDST() == 1){
Time.beginDST();
else {
Time.endDST();
bool isDST()
{ // (Central) European Summer Timer calculation (last Sunday in March/October)
int dayOfMonth = Time.day();
int month = Time.month();
int dayOfWeek = Time.weekday() - 1; // make Sunday 0 .. Saturday 6
if (month >= 4 && month <= 9){ // April to September definetly DST
return true;
else if (month < 3 || month > 10){ // before March or after October is definetly standard time
return false;
// March and October need deeper examination
boolean lastSundayOrAfter = (dayOfMonth - dayOfWeek > 24);
if (!lastSundayOrAfter){ // before switching Sunday
return (month == 10); // October DST will be true, March not
if (dayOfWeek){ // AFTER the switching Sunday
return (month == 3); // for March DST is true, for October not
int secSinceMidnightUTC = Time.now() % 86400;
boolean dayStartedAs = (month == 10); // DST in October, in March not
// on switching Sunday we need to consider the time
if (secSinceMidnightUTC >= 1*3600){ // 1:00 UTC (=1:00 GMT/2:00 BST or 2:00 CET/3:00 CEST)
return !dayStartedAs;
return dayStartedAs;
void digitalClockDisplay(){
lcd->print(Time.year(), DEC);
lcd->print('/');
if(Time.month()<10) lcd->print('0');
lcd->print(Time.month(), DEC);
lcd->print('/');
lcd->print(Time.day(), DEC);
lcd->print(' ');
if(Time.hour()<10) lcd->print('0');
lcd->print(Time.hour(), DEC);
lcd->print(':');
if(Time.minute()<10) lcd->print('0');
lcd->print(Time.minute(), DEC);
lcd->print(':');
if(Time.second()<10) lcd->print('0');
lcd->print(Time.second(), DEC);
int MobileSwitch(String command) {
if (command=="off") {
ForceState = -1;
return 0;
else if (command=="on") {
if(radikaC > 39){
ForceState = 1;
//digitalWrite(relayRadiator, HIGH);
return 1;
else{
return -1;
else if (command=="auto") {
ForceState = 0;
return 1;
else {
return -1;
MQTT callback function (i changed library void callback to float callback so i could retrieve values from it, it works on my other project):
char p[length + 1];
p[length] = NULL;
if(radikaC > 39){
ForceState = 1;
ForceState = -1;
ForceState = 0;
Part of code that starts/stops pump:
c = 1;
c = 0;
return c;
