Thank you @shanevanj and @ScruffR for responding, Here is the code, all variables are declared in a separate header file
#include <MQTT.h>
#include <neopixel.h>
#include "clo2_config.h"
// IMPORTANT: Set pixel COUNT, PIN and TYPE
Adafruit_NeoPixel strip(PIXEL_COUNT, PIXEL_PIN, PIXEL_TYPE);
void mqtt_callback(char* topic, byte* payload, unsigned int length);
MQTT client(ip_address, port, mqtt_callback);
enum {
MQTT_IDLE,
MQTT_PROCESS_COMMAND,
MQTT_TOGGLE_SYSTEM,
MQTT_PREPARATION_TIME,
MQTT_CHLORINATION_TIME,
MQTT_RESET_SYSTEM
int mqtt_state = MQTT_IDLE;
char mqtt_command[16];
int led_heartbeat() {
digitalWrite(onboard_led, switch_flag);
void get_device_ID() {
device_ID = System.deviceID();
void setup_variables() {
Particle.variable("trg_src", trigger_source);
Particle.variable("pixel_color", pixel_color_string);
Particle.variable("fan_state", fan_state);
Particle.variable("buzzer_state", buzzer_state);
Particle.variable("current_state", triggered_event);
Particle.variable("prep_time", prep_time);
Particle.variable("chlorination_time", chlorination_time);
void setup_neopixel()
strip.begin();
strip.show(); // Initialize all pixels to 'off'
void convert_color_to_string() {
switch (pixel_color) {
case RED:
pixel_color_string = "RED";
break;
case GREEN:
pixel_color_string = "GREEN";
break;
case BLUE:
pixel_color_string = "BLUE";
break;
case YELLOW:
pixel_color_string = "YELLOW";
break;
default:
pixel_color_string = "UNKNOWN";
break;
void set_pixel_color(uint32_t c) {
for(int i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
void flash_neopixel(unsigned long _pixel_period, uint32_t color) {
if((millis() - pixel_timer) > _pixel_period) {
pixel_flag = !pixel_flag;
if(_pixel_period == ALWAYS_ON) {
pixel_flag = true;
if(pixel_flag) {
set_pixel_color(color);
else{
set_pixel_color(0);
pixel_timer = millis();
void toggle_fans(bool _state) {
digitalWrite(fan_1, _state);
digitalWrite(fan_2, _state);
void toggle_buzzer(bool _state) {
if(!buzzing_state) {
digitalWrite(buzzer, !_state);
void process() {
* start
* Check power
* check start button press
* flash yellow light in preparation
* wait 2 hours
* start both fans
* flash green for chlorination
* trigger buzzer
* wait 2 hours
* flash blue to show end of process and trigger buzzer
* check for power button press
* end
if( switch_flag ) { // start system only if button is pressed
unsigned long _system_timer_local = millis() - systme_timer;
if( _system_timer_local <= prep_time ) { // system is off, pulsing every two seconds
buzzer_state = false;
fan_state = false;
pixel_color = GREEN;
pixel_period = TWO_SECONDS;
triggered_event = "Preparation start";
if(publish_counter = 0) {
ready_to_send_data = true;
publish_counter = publish_counter + 1;
else if( (_system_timer_local <= (chlorination_time + prep_time)) && (_system_timer_local > prep_time) ) { // system is on blinks every half a second
buzzer_state = true;
fan_state = true;
pixel_period = ALWAYS_ON;
triggered_event = "Chlorination start";
if(publish_counter = 1) {
else if( (_system_timer_local <= (chlorination_time + ONE_SECOND)) && (_system_timer_local > chlorination_time) ) { // system is off at the end blinks blue
fan_state = false;
pixel_period = HALF_A_SECOND;
triggered_event = "Process conclusion";
if(publish_counter = 2) {
// systme_timer = millis();
else {
switch_flag = false;
triggered_event = "Process complete";
if(publish_counter = 3) {
else { // keep all systems off and pixel flashing red
fan_state = false;
publish_counter = 0;
/**** Online Functions ***/
int toggle_system_remotely(String _state) {
_state.toUpperCase();
if( _state == "ON" ) {
if(!switch_flag) { // only turn on if system is not runing
switch_flag = true;
triggered_event = "System remote turn on";
buzzer_counter = 4;
buzzing_state = true;
else if( _state == "OFF" ) {
if(switch_flag) { // only turn off if system is runing
triggered_event = "System remote turned off";
buzzer_counter = 4;
trigger_source = PARTICLE_TRIG;
return switch_flag; // return the switch_state.
int fan_test(String _state) {
fan_state = 1;
else {
fan_state = 0;
return fan_state;
int ptcl_tgl_sys(String _tgl) {
return toggle_system_remotely(_tgl);
int mqtt_tgl_sys() {
String _tgl = read_command_payload(mqtt_command);
trigger_source = MQTT_TRIG;
int change_preparation_time(String _prep_time) { // this will stop a process that's running
switch_flag = false; // switch off system first
int _num_of_mins = _prep_time.toInt();
prep_time = ONE_MIN * _num_of_mins;// change the time;
systme_timer = millis(); // reset the system time
triggered_event = "prep time updated";
return prep_time;
int ptcl_prep_t(String _prep) {
return change_preparation_time(_prep);
int mqtt_prep_t() {
String _prep = read_command_payload(mqtt_command);
int change_chlorination_time(String _cl_time) { // this will stop a process that's running
int _num_of_mins = _cl_time.toInt();
chlorination_time = ONE_MIN * _num_of_mins;// change the time;
triggered_event = "Chlorination time updated";
return chlorination_time;
int ptcl_chnge_cl(String _cl) {
return change_chlorination_time(_cl);
int mqtt_chnge_cl() {
String _cl = read_command_payload(mqtt_command);
int reset_system(String _reset) { // reset system to defaults
_reset.toUpperCase();
if( (_reset == "RESET") || (_reset == "R") ) {
prep_time = ONE_MIN;
chlorination_time = ONE_MIN;
triggered_event = "System Reset";
return 1;
int ptcl_rst_sys(String _reset) {
return reset_system(_reset);
int mqtt_rst_sys() {
String _reset = read_command_payload(mqtt_command);
void publish_data() {
if(ready_to_send_data) {
// publish_to_particle();
pulish_to_mqtt();
ready_to_send_data = false;
void publish_to_particle() {
Particle.publish("system_event", triggered_event, PRIVATE);
void pulish_to_mqtt() {
String _payload_;
String system_event = "\"system_event\":";
String id = "\"id\":\"";
String publish_counter_str = "\",\"publish_counter\":\"";
String trig = "\",\"trigger_source\":\"";
String state = "\",\"state\":\"";
String led = "\",\"led\":\"";
String fan = "\",\"fan\":";
String buzzer = ",\"buzzer\":";
String _prep_time = ",\"prep_time\":";
String _chlorination_time = ",\"chorination_time\":";
String trig_source_str;
switch (trigger_source) {
case PARTICLE_TRIG:
trig_source_str = "PARTICLE";
break;
case BUTTON_TRIG:
trig_source_str = "BUTTON";
break;
case MQTT_TRIG:
trig_source_str = "MQTT";
break;
default:
trig_source_str = "-";
break;
String fan_state_str;
fan_state_str = fan_state ? "ON" : "OFF";
String buzzer_state_str;
buzzer_state_str = buzzer_state ? "ON" : "OFF";
_payload_.concat('{');_payload_.concat(system_event);
_payload_.concat(id);_payload_.concat(device_ID);
_payload_.concat(trig);_payload_.concat(trig_source_str);
_payload_.concat(publish_counter_str);_payload_.concat(publish_counter);
_payload_.concat(state);_payload_.concat(triggered_event);
_payload_.concat(led);_payload_.concat(pixel_color_string);
_payload_.concat(fan);_payload_.concat(fan_state_str);
_payload_.concat(buzzer);_payload_.concat(buzzer_state_str);
_payload_.concat(_prep_time);_payload_.concat(prep_time);
_payload_.concat(_chlorination_time);_payload_.concat(chlorination_time);
_payload_.concat('}');_payload_.concat('}');
mqtt_connect();
for(int i = 0; i < 10; i++) {
if (client.isConnected()) {
break;
delay(100); //wait 100mS
if (!client.isConnected()) {
return;
client.publish(topic, _payload_);
mqtt_disconnect();
void init_online_functions() {
Particle.function("toggle_system_remotely", ptcl_tgl_sys);
Particle.function("change_preparation_time", ptcl_prep_t);
Particle.function("change_chlorination_time", ptcl_chnge_cl);
Particle.function("reset_system", ptcl_rst_sys);
Particle.function("test_fans", fan_test);
/* MQTT functions */
void mqtt_state_machine() {
switch (mqtt_state) {
case MQTT_IDLE:
//get new commands
client.subscribe(topic);
break;
case MQTT_PROCESS_COMMAND:
mqtt_state = read_mqtt_state(mqtt_command);
break;
case MQTT_TOGGLE_SYSTEM:
mqtt_tgl_sys();
clear_mqtt_buffer();
break;
case MQTT_PREPARATION_TIME:
mqtt_prep_t();
break;
case MQTT_CHLORINATION_TIME:
mqtt_chnge_cl();
break;
case MQTT_RESET_SYSTEM:
mqtt_rst_sys();
break;
default:
//unknown state
break;
void mqtt_callback(char* topic, byte* payload, unsigned int length) {
if (length <= sizeof(mqtt_command)) {
memcpy(mqtt_command, payload, length);
mqtt_state = MQTT_PROCESS_COMMAND;
else {
//ignore everything too large to handle
void clear_mqtt_buffer() {
memset(mqtt_command, 0, sizeof(mqtt_command));
int read_mqtt_state(char * _mqtt_command) {
return _mqtt_command[0] - '0';
String read_command_payload(char * _mqtt_command) {
String _cmd = String(_mqtt_command);
_cmd.trim();
return _cmd.substring(2); // cut off the state and comma
void mqtt_subscribe_only_when_idle() {
if(mqtt_state != MQTT_IDLE) {
client.unsubscribe(topic);
void mqtt_connect() {
// int id_len = device_ID.length();
// char _id[id_len];
// sprintf(_id, "%s", device_ID);
client.connect(device_ID); //connect to device ID
void mqtt_disconnect() {
client.disconnect();
void keep_mqtt_alive() {
mqtt_connect();
void setup_mqtt(void)
mqtt_connect();
client.publish(topic,"DEVICE RESTART");
void mqtt_loop() {
// keep_mqtt_alive();
// mqtt_state_machine();
// mqtt_subscribe_only_when_idle();
void button_poll() {
if((millis() - button_timer) > button_poll_interval) { // check button state every half a second
if(!digitalRead(_button)) { //if the button is pressed, increase button counter
button_counter++;
actionable_button_counter = button_counter;
else {
button_counter = 0; // reset to zero
button_timer = millis(); //reset_timer;
void action_button_press() {
if(button_counter == 0) { //check if there has been a button press not yet actioned
if(actionable_button_counter < 1) {
actionable_button_counter = 0; //not held long enough, reset
else if(actionable_button_counter >= 1) {
switch_flag = !switch_flag;
trigger_source = BUTTON_TRIG;
buzzer_counter = 4;
actionable_button_counter = 0; // reset actionable counter to zero
void buzzer_handle() {
if(buzzing_state) {
if((millis() - buzzer_timer) > buzzer_period) {
digitalWrite(buzzer, !digitalRead(buzzer));
buzzer_counter--;
buzzer_timer = millis();
if(buzzer_counter <= 0) {
digitalWrite(buzzer, HIGH);
buzzing_state = false;
/**** System functions ****/
// Get the DEvice ID
get_device_ID();
// Setup online variables
setup_variables();
//init remote functions
init_online_functions();
//init the neopixel
setup_neopixel();
//init mqtt
setup_mqtt();
//init the onboard led
pinMode(onboard_led, OUTPUT);
//init fan relay pins
pinMode(fan_1, OUTPUT);
pinMode(fan_2, OUTPUT);
//init buzzer pin
pinMode(buzzer, OUTPUT);
//init button pin
pinMode(_button, INPUT_PULLUP);
//publish data
publish_data();
// delay(10000);
// ready_to_send_data = true;
// flash the onboard led
led_heartbeat();
// flash neopixel
flash_neopixel(pixel_period, pixel_color);
// toggle fan states
toggle_fans(fan_state);
// toggle buzzer
toggle_buzzer(buzzer_state);
// Run process
process();
// Update color string
convert_color_to_string();
// monitor button press
button_poll();
// Action button press
action_button_press();
// buzzer handler
buzzer_handle();
// Run through the mqtt mqtt_loop
mqtt_loop();
