Photon/Core and CAN-Bus SN65HVD232
So I’ve got both the Photon and the Core and I’ve built a board with an Texas Instrument CAN-Bus transceiver (http://www.ti.com/product/SN65HVD232) and hooked it’s outgoing pins to the TX/RX pins of the board. But now I’m stuck, is there any good way to read and potentially send messages over the can-bus and relay them to the USB (Serial port) for reading?
I would be forever grateful for any input and example code to help me get started.
I’m using the SN65HVD232 and the RX/TX pins on the chip are the D/R pins and they are connected directly to the Particle’s serial pins.
Are you using the UART Rx and Tx or the CAN Rx and Tx? I don’t think the Core had the CAN pins exposed.
There is a big difference between UART and CAN in the micro.
I have not received my photon yet (CAN is supposed to be exposed) and I ordered a CAN transceiver last night so once I get all my stuff I might be able to help.
CAN is exposed with D1/D2.
I haven’t looked at the API yet but are there functions to send and receive 11 & 29 bit messages?
Not asking for hi level protocols just the basics.
Don’t think any work was done on CAN yet
I wrote a CAN driver for the stm32f2xx about 4 years ago… I wonder if I can dig something up.
Or do you rely on ST’s libraries?
I guess looking at ST appnote would be a great place to start with :smile:
Did you get any further with this?
Sorry I have not had a chance to play with this yet. Kids, hospital, so many gadgets, work…
