Hi both, thanks for the feedback.
Firstly, I tried Device Doctor again and selected the "Advanced" option and set the WiFi antenna to internal and tried again. Sadly same results.
I've also tried the Device Restore / Web Based Setup and still no further forward.
Using the Web Based Setup - i've captured the logs.
Device is going in DFU: 0a10aced202194xxxxxxxxxx
The device is connected: 0a10aced202194xxxxxxxxxx
Reconnecting device: 0a10aced202194xxxxxxxxxx
The device is in DFU MODE: 0a10aced202194xxxxxxxxxx
Getting device: 0a10aced202194xxxxxxxxxx
Getting Device OS information for p2
Downloading binary: p2-bootloader@5.5.0.bin
Downloading binary: p2-prebootloader-part1@5.5.0.bin
Downloading binary: p2-system-part1@5.5.0.bin
Downloading binary: p2-tinker@5.5.0.bin
Updating modules over DFU
Updating module: p2-system-part1@5.5.0.bin
Updating module: p2-tinker@5.5.0.bin
Updating over DFU succeeded
reconnected
Update device over control request
Put the device in listening mode: 0a10aced202194xxxxxxxxxx
Updating module p2-prebootloader-part1@5.5.0.bin
Warn: Cannot put the device in listening mode: IN control transfer failed
Updating module p2-bootloader@5.5.0.bin
The process seems to get stuck at the p2-bootloader@5.5.0.bin - eventually the device stops responding and then resets and trys again.
Any more ideas?
BTW, i noticed on the forum another person is getting same problem?
Photon 2 - unable to setup - Cloud - Particle
