Nothing changed between the 2 runs. But through particles DFU can find 2
[root@localhost ~]# sudo particle flash --usb tinker
Apparently I didn't find a DFU device? util said
Error writing firmware... no dfu device found.
[root@localhost ~]# dfu-util -l
dfu-util 0.8
Found DFU: [2b04:d006] ver=0200, devnum=28, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01*016Kg", serial="00000000010C"
Found DFU: [2b04:d006] ver=0200, devnum=28, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg", serial="00000000010C"
[root@localhost ~]#
Hey there, are you trying the say that the firmware was not flashed?
"sudo particle flash --usb tinker"
This should flash the firmware, but it failed.
Centos 7, dfu-util 0.8, latest particl-cli 1.15
I guess it doesn’t work with particle flash --usb tinker as well?
Device flashing yellow (in dfu mode)
➜ ~ dfu-util -l
dfu-util 0.8
dfu-util: Cannot open DFU device 2b04:d006
➜ ~ particle flash --usb tinker
Apparently I didn’t find a DFU device? util said dfu-util 0.8
Error writing firmware… no dfu device found.
Hmmm…
I’m not entirely sure if it’s an issue with your account requiring sudo dfu-util -l in order to list things properly…
Anyway, what are you want to flash via DFU? We can use the DFU-commands for now.
flash a simple analog read and print back to serial command app.
Would you prefer to use the Web IDE and flash via OTA for now?
It will be great for the application that you want to do since using the particle-cli you still need to compile code and flash via DFU
If I am at home, I would be able to play with Web IDE. But When I am at work, I am behind many layers of proxy and filtering (those stuff blocks certain communication). particle-cli is the only viable solution when I am at work. (Corporate laptop has usb ports locked, so I am using my personal laptop via guest network(
Ok so the command will be:
dfu-util -d 2b04:d006 -a 0 -s 0x80A0000:leave -D name_of_file.bin
You can also see how to compile using the particle-cli at: https://github.com/spark/particle-cli#compiling-remotely-and-flashing-locally
