I have 3 different webhooks set up for Particle devices for customers in different geographical regions (NA, Europe, Asia) as my serverless endpoints are regional. The particle.publish() event names are respectively (see below):
scanscan_europescan_asia
I started with only NA customers only and then began adding on international customers. However, as reported by a customer, the scan_europe events are also simultaneously hitting the scan endpoint causing duplicate events.
I also just verified this again on my end by creating a separate scan_dev event name and seeing it hit the scan endpoint. When I change the event name to just dev it does not.
Did I somehow miss this in the documentation? If this is a bug, can it be resolved so that I don’t have to individually flash unique event names for the various devices that are already out in the field?
Thank you.
