I’ve some problems with Raspberry Pi and Particle Camera. When I try to compile the code I’ve some problems. The libraries inside the code is ws2811.h, but after the library ws2811.h I’ve putted inside the code others library. But after all the installed libraries the particle Build give me an error:
/workspace/rpihw.h:36:5: error: ‘uint32_t’ does not name a type
uint32_t type;
This is the tutorials:
https://docs.particle.io/tutorials/projects/particle-pi-security-camera/
Can I download the github firmware code and putting in the Particle Build?
