Hi!
I have created a webhook under integrations in the dashboard. I now wanna change some of the content, is that possible ? or do i have to delete and create a new one ?
Currently, the only way to change a webhook is to delete it and create a new one.
ohhh
that sux… but okay thanks for answer!
@hoaben13, or, you can use Particle CLI to create webhooks using a .json file containing your webhook configuration. The ONLY way to modify a webhook is to delete it and recreate it.
