Particle photon external antena how to HELP?
how do you switch from the internal antenna to a exterior one?? I have read the docs and did some searches and cant find out how to do it…
https://docs.particle.io/reference/firmware/photon/#selectantenna-antenna-
But where do you go or what software do you install to do that?
@Smitty, that is a command you add to your own application that you compile and flash over to the Photon via OTA or DFU. Perhaps explaining what you are trying to do would help.
The same way as you would write and flash any other firmware to the Photon.
Have had anything done with the Photon before?
(too slow again)
Thanks everyone… what I did that worked was add the external antenna command to the first line of my program code and it worked
