italex
December 2, 2025, 2:48pm
1
Hi Folks,
I am trying to use ameba_soc.h, but I am getting errors.
include "application.h"
extern "C" {
#include "ameba_soc.h" // For hardware timer access
This code returns :
timer_init_t coolCycleTimer;
timer_init_t heatCycleTimer;
'timer_init_t' does not name a type
Is that true that Particle does not expose hardware timer APIs on the Photon 2 (RTL872x chipset), and that the cause of the error?
Thank you,
Alex
Particle is not based on Ameba IoT, so that won't work. How did you even get that to compile? That header file isn't anywhere in Device OS.
The RTL872x has very few hardware timers available, and judging from the name, you should be using a software-based timer instead.
italex
December 3, 2025, 12:53am
3
Hi rickkas7,
Well, it never compiled; I got errors, as I mentioned. I was curious because hardware timers are more precise than software timers. That’s all. I use software timers all the time.
Thanks a lot for the reply!
Alex
