I’m trying to get a desktop development environment going. I’ve installed atom, then installed particle-dev and a number of dependencies using apm. Here are the current “community packages” I have installed for atom:
Community Packages (14) /home/mike/.atom/packages
├── busy-signal@1.4.1
├── console-panel@0.2.1
├── intentions@1.1.2
├── linter@2.1.4
├── linter-gcc@0.7.1
├── linter-ui-default@1.6.0
├── particle-dev@0.1.21
├── particle-dev-cloud-functions@0.1.0
├── particle-dev-cloud-variables@0.1.0
├── particle-dev-complete@1.0.1
├── particle-dev-libraries@0.2.18
├── particle-dev-local-compiler@0.1.0
├── particle-dev-profiles@0.1.15
└── tool-bar@1.1.0
When I start the GUI, I don’t see any entries in the Particle menu – it just appears blank. Also, after I installed the “particle-dev-local-compiler” package (in an attempt to get something to show up in that menu), I now get this error at startup:
Unable to connect to Docker.
Check if Docker is running (you can use docker ps -a in command line).
I installed docker, added my account to the “docker” group, and can run “docker ps -a” myself, but whatever is trying to use it from within atom doesn’t like it, I guess.
What do I need to do to get the Particle menu populated? Or does that simply not work under Linux?
