Particle JS Unclaim Device?
is there such a thing as particle.unclaimDevice similar to particle.claimDevice?? Yes, I saw the document for curl command for uncliaming the device.
Thanks.
I believe particle.removeDevice is what you want.
That does a HTTP DELETE on the /v1/devices/:deviceID endpoint like the unclaim a device example does.
Thank you so much @rickkas7.
