I am trying to use the particle node module (https://docs.particle.io/reference/SDKs/javascript/#node-js) and when I try to create a customer for a product with something like this:
var Particle = require('particle-api-js');
var particleClient = new Particle({
clientSecret: 'MY SECRET',
clientId: 'MY CLIENT ID'
particleClient.createCustomer({ email: SOMEEMAIL, password: SOMEPASSWORD, product: PRODUCT SLUG})
When I go with that approach I never see the Customer in my customers tab of my Particle Console but I do get an access token back from the call. Also, I am trying to do two-legged auth which means I need to create shadow customers using the noPassword option and not pass a password but the module does not support this at all.
Am I missing something glaring? I’m a bit lost with this as I can’t create a simple customer for my Product. I have already created a two legged Oauth client in the Auth tab of my Product and am initializing the particle client above using that client id and secret.
