I wanted to know if the Particle Electron was compatible with ThingSpeak. I did not see this device as supported on ThingSpeak website. I wanted to use GSM not wifi to trasmit the data to their site. If they are, could someone point me in the right direction for supporting libraries.
The official ThingSpeak library is compatible with Photon and Electron.
As a user of Photons, Electron, and ThingSpeak, I can confirm that the library which is published by “The MathWorks” in the Particle environments named “ThingSpeak” is both easy to use and works very well.
Thanks so much for verification and link.
